Tensile Stress and shear stress
In summary, the conversation discusses the behavior of mild steel when it is pulled from both ends. The stress on the material is tensile in nature and there is no compressive stress. If the pulling force exceeds the yield strength of the material, it will undergo plastic deformation and strain hardening. The formation of a neck on the middle portion of the material can lead to failure. However, it is not considered a form of shear failure as there is no shearing happening in tension. The formation of a neck is a result of Poisson's effect and strain hardening. Mohr's circle can be used to analyze the stress on a tensile test specimen, where the maximum shear stress is equal to half the maximum normal stress acting at a
giri
Suppose, a mild steel bar is being pulled from both ends.The stress acting on it will be tensile in nature.There is no compressive stress on material in this situation.When the pull exceeds material's yield strength,plastic deformation and strain hardening will occur.If pulling force is increased, neck may form on middle portion of material, which may lead to material failure.Here can I consider necking process is a form of shear failure and the stress lead to necking is shear stress?
No I don't think you can because in tension nothing's shearing. As you said, necking is a product of Poisson's effect and strain hardening.
For your tensile test specimen, look at Mohr's circle. A stress block oriented parallel and perpendicular to the specimen long axis shows max normal stress on the transverse sides and zero normal stress on the axial sides. This means that there is a max shear stress equal to half the max normal stress acting at 45 deg to the long axis. As the specimen necks down, there is definitely shearing action happening along a 45 deg line; this should be visible in an actual test in the latter stages.
Likes timthereaper and Chestermiller
Related to Tensile Stress and shear stress
What is tensile stress?
Tensile stress is a type of stress that occurs when a material is pulled or stretched in opposite directions. It is also known as tension stress and is measured in units of force per unit area, such as newtons per square meter (N/m2).
What is shear stress?
Shear stress is a type of stress that occurs when a material is being pushed in opposite directions, causing the material to deform or twist. It is also measured in units of force per unit area, such as newtons per square meter (N/m2).
What is the difference between tensile stress and shear stress?
The main difference between tensile stress and shear stress is the direction of the force applied. Tensile stress occurs when a material is being pulled or stretched in opposite directions, while shear stress occurs when a material is being pushed in opposite directions. Additionally, the type of deformation that occurs is different for both types of stress.
How do you calculate tensile stress?
Tensile stress can be calculated by dividing the applied force by the cross-sectional area of the material. The formula for tensile stress is σ = F/A, where σ is the tensile stress, F is the applied force, and A is the cross-sectional area of the material.
What materials are typically strong in tensile stress?
Materials that are typically strong in tensile stress include metals, such as steel and titanium, as well as materials with long molecular chains, such as polymers and composites. These materials have strong intermolecular forces that allow them to resist being pulled apart.
  • Mechanical Engineering
