Tensile Test of Slip Ring - Working out Tensile Strength
The discussion focuses on the tensile testing of slip rings using an old technique from BS HC 403:1977. The method involves creating a slit in the ring and applying tensile force while ensuring the slit is perpendicular to the force direction. The formula for calculating tensile strength is provided, with specific variables defined. A key question arises regarding the derivation of the force equation, F = 3P((D/t) - 1), and how it relates to the standard stress formula S = F/A. Clarification on the original formula's derivation is sought to understand its application in tensile strength calculations.
Delvaurius
All,
Through work, I've recently been tasked with investigating a very old tensile test technique, according to BS HC 403:1977 (now withdrawn).
Essentially, you take a ring. Anywhere along it you make a slit all the way through. You then pull that ring in a tensile machine, ensuring that the slit is perpendicular to the direction of force.
The standard then states, to work out the tensile strength, use the equation:
S = (3*P*((D/t)-1)) / b*t
S = Stress, P = Load, D = Outer Diameter, t = radial thickness, b = width.
Now I get the whole thing over (b*t) where b*t is the cross sectional area of the ring, meeting S=F/A.
How is Force = 3P((D/t) - 1) derived?
Thanks for any help!
In your converted formula F = P; instead, you should be seeking the derivation of the original formula as stated.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
14K
9K
  • · Replies 16 ·
