Tension, A Rope with Mass problem
In summary, a clotheline with mass M is hung from two poles, with each end making an angle [theta] with the horizontal. The tension in the ends of the rope can be determined by balancing the weight of the rope with the tension at each end. The tension at the sagging point in the rope is not zero and can be approximated using a parabolic curve. The tension forces always act tangent to the curve of the rope and pull away from it, and vary in magnitude and direction along the rope's length.
k-rod AP 2010
36
A clothsline with mass M is hung from two poles, and each end makes angle [theta] with the horizontal. The middle of the rope sags under its own weight. a) what is the tension in the ends of the rope? b)the tension at the sagging point in the rope?
I drew free body diagrams for the ends and middle of the rope and i figured that the rope's weight (m*g) is the only force and is balanced by the tension T at the ends of the rope. So the tension at each end would be 1/2(m*g) b/c each end is holding half the weight.
And the T at the middle of the rope is 0 b/c it is sagging and the (m*g) isn't being balanced by any other force.
Am I correct? i am honestly not too sure how tension works so any help would be appreciated.
No, this is not correct. A rope sagging under its own weight takes the shape of a catenary, but as long as the sag is not a large percentage of the span, you can approximate the curve as a parabola with very small error. So in your free body diagram that isolates the left end and middle point of the rope from the right half of the rope, identify all forces acting on the rope. There is the weight force acting down, and forces at each end of the rope. The tension in the rope at midpoint is NOT zero.
HINT: Tension forces always act tangent to the curve of the rope and pull away from it, that is, tension is a pulling force acting along the longitudiinal curved axis of the rope, and varies in magnitude and direction along the rope's length. Since the rope is in equilibrium, apply Newton's first law. You might want to calculate the vertical support reactions first, before drawing the FBD of the left half of the rope.
Ok that makes sense, ur explanation and my teacher's helped me get the correct answer, thanks.
FAQ: Tension, A Rope with Mass problem
What is tension in a rope with mass problem?
Tension refers to the force exerted by a rope when it is stretched between two points. In a rope with mass problem, the rope itself has a mass which adds to the tension force.
How is tension calculated in a rope with mass problem?
Tension is calculated by taking into consideration the mass of the rope, the acceleration due to gravity, and the length of the rope. The formula for tension is T = mg + ma, where T is tension, m is the mass of the rope, g is the acceleration due to gravity, and a is the acceleration of the rope.
What factors affect tension in a rope with mass problem?
The factors that affect tension in a rope with mass problem include the mass of the rope, the length of the rope, and the acceleration of the rope. Additionally, external forces such as friction and air resistance can also affect tension.
How does tension in a rope with mass problem impact the motion of the rope?
Tension plays a crucial role in the motion of a rope with mass. It is the tension force that causes the rope to accelerate and move. The direction of the tension force will determine the direction of the rope's motion.
Can the tension in a rope with mass problem ever be equal to zero?
No, the tension in a rope with mass problem can never be equal to zero. This is because the rope itself has a mass which will always contribute to the tension force. However, the tension can be reduced to a very small value if the mass of the rope is negligible in comparison to other factors.
