Tension and Newtons Second Law
In summary, a student attempts to raise a chain consisting of three identical links with a mass of 200 g each. The chain is connected to a string and suspended vertically, with a force of 12 N being applied by the string. Using Newton's laws, the acceleration of the chain is found to be 20 m/s^2. Additionally, the force exerted by the top link on the middle link is determined by drawing a free body diagram and considering the forces acting on the top link.
Prof. 27
50
A student tries to raise a chain consisting of three identical links. Each link has a mass of 200 g . The three-piece chain is connected to a string and then suspended vertically, with the student holding the upper end of the string and pulling upward. Because of the student's pull, an upward force of12 N is applied to the chain by the string. Use Newton's laws to answer the following questions.
a) Find the acceleration of the chain.
b) Find the force exerted by the top link on the middle link.
F = ma
MIT Opencourseware
Physics Clasroom
Hyperphysics
Lots of scratch paper and failed attempts
Let's see some of your failed attempts. We can't help you if we can't see what your hangup is.
Chet
Okay:
So we know each link is 200g. So the total mass of the three chains is 600 g, which we convert to 0.6 kg.
We know the chain is initially suspended (at rest, i.e. there is no vertical acceleration); therefore the vertical force upward equals the vertical force downward (gravity) - 12 N. Since the string is massless, frictionless, etc. We can plug it into Newton's second law.
12 N = 0.6 kg*a
So 12 N/0.6 kg = a
So: a = 20 m/s^2
This is wrong according to the Mastering Physics.
This force balance omits an important force. Have you drawn a free body diagram? What are the forces acting on the chain?
Likes Prof. 27
Do you mean the net force will be a vertically upward force equal to that? If so, doesn't something there seem backwards?
Prof. 27 said:
12 N = 0.6 kg*a
You mentioned gravity before, but I don't see that in this equation.
Likes Prof. 27
Thanks so much. Got it.
So now having trouble with part two. Wouldn't the only force the top link exerts on the middle one be the force of gravity on the top link since the person pulling the string upward is applying the other force (and it is upward, so the force of the middle would be applied to the force on the top, vice versa) and so its not part of the force of the top chain on the middle?
I can't follow what you are saying here. Please draw a free body diagram of the top link showing all the forces acting on it. Please say in your own words what these forces are (there are three of them). (You really need to get used to always drawing free body diagrams).
Related to Tension and Newtons Second Law
What is tension?
Tension is the force that is transmitted through a string, cable, or other similar object when it is pulled tight by forces acting on either end.
What is Newton's Second Law?
Newton's Second Law, also known as the Law of Acceleration, states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass.
How does tension relate to Newton's Second Law?
Tension is an example of a force that can act on an object and cause it to accelerate, as described by Newton's Second Law. The magnitude and direction of the tension force can affect the object's acceleration.
How can we calculate tension?
Tension can be calculated using Newton's Second Law and the known forces acting on an object. The formula for tension is T = ma, where T is the tension force, m is the mass of the object, and a is the acceleration.
What are some real-life examples of tension and Newton's Second Law?
Some examples of tension and Newton's Second Law in action include a person pulling a rope to lift a heavy object, a car accelerating due to the tension in its tires, and a pendulum swinging back and forth due to the tension in its string.
