Tension and reaction force in circular motion
In summary, when the rod is in compression, there is a negative force and when the rod is in tension, there is a positive force.
Like Tony Stark
179
Consider a rotating rod with a mass attached to its end.
When does the rod produce a compression force and when a tension force?
##\hat n) F_n=mr\omega^2##
Hi
I'm having trouble to understand the centripetal force in a rotating rod with a mass in its end.
When ##90°<\theta<270°##, the centripetal acceleration is produced by the tension, which counteracts the radial component of the weight.
But what happens when ##\theta<90°## or ##\theta>270°##? There's no tension because the force (weight) is towards the centre, so the weight causes the centripetal acceleration. Right?
As the rod is rigid, I think that, for some interval of ##\theta##, the rod produces a force that acts as a tension force and for other interval it acts as a compression force. Would this interval be compression for ##\theta<90°## and tension for ##90°<\theta<270°##?
Then, in the case of a string instead of the rod, the centripetal acceleration is produced by the tension and when ##\theta<90°## it is produced by the weight.
you did not consider gravity?
what if ##\omega## is really large, like ##\ \gt \sqrt{g/r\ }## ?
Hi. There are some misconceptions in what you have written. See if this helps. Sorry it's rather long.
Sometimes, extreme cases give a physical insight. Suppose the mass is moving really fast. Intuitively, you should ‘get’ that the rod is always in tension (like a string would be). So your statement:
“There's no tension because the force (weight) is towards the centre,”
is wrong in this situation.
I probably shouldn’t explain in this detail, but see if it helps...
For convenience, use the convention: radially inwards is positive, and radially outwards is negative. So if the rod is in tension, T>0, as the rod is pulling the mass radially inwards. And, correspondingly, if the rod is in compression, we can say T<0.
For a mass M on the end of a rod (length L), rotating at constant speed in a vertical circle, the resultant force, F, acting on M is the vector sum of:
1) the radial component of weight, m|g|cosθ;
2) the tension or compression in the rod, T.
(I’ve used |g| to avoid confusion if taking g as a negative value).
If M is in the upper half of the circle, cosθ is positive so the radial component of weight (m|g|cosθ) is positive, acting radially inwards, as it must.
If M is in the lower half of the circle, cosθ is negative so the radial component of weight (m|g|cosθ) is negative, acting radially outwards, as it must.
And note that T is not a constant force. T is a function of M, L, speed(v) and θ. T continuously changes throughout each revolution.
If M, L and v are constant we can treat T as a function of θ, so write it as T(θ)
I’ll explain how we can work out T(θ) for any value of θ, and why it can be positive or negative.
Resultant force on M is:
F = T(θ) + m|g|cosθ
For circular motion at constant speed v, centripetal force = resultant force = mv²/L so:
mv²/L = T(θ) + m|g|cosθ
T(θ) = mv²/L - m|g|cosθ
= m(v²/L - |g|cosθ)
If v²/L > |g|cosθ then T is positive so rod is in tension.
If v²/L <|g|cosθ then T is negative so rod is in compression.
If you think about it, this shows for large enough values of v, T is always in tension.
And for small values of v, T is in compression for part of the rotation and in tension for the other part.
(Sorry, for speed I didn't use Latex.)
Likes Like Tony Stark
Related to Tension and reaction force in circular motion
What is tension in circular motion?
Tension is the force that is transmitted through a string, rope, or other similar object when it is pulled taut. In circular motion, tension is the force that keeps an object moving in a circular path.
What is the reaction force in circular motion?
The reaction force in circular motion is the force that is exerted by an object on the center of the circle, in the opposite direction of the centripetal force. It is equal in magnitude and opposite in direction to the centripetal force, and is necessary to maintain the circular motion of the object.
How is tension related to centripetal force in circular motion?
In circular motion, tension is one of the components of the centripetal force. The centripetal force is the net force acting towards the center of the circle, and it is made up of the tension force and any other forces acting on the object in the direction of the center of the circle.
What happens to tension and reaction force when the speed of circular motion increases?
As the speed of circular motion increases, the tension and reaction force also increase. This is because a higher speed requires a greater centripetal force to maintain the circular motion, which in turn requires a higher tension and reaction force.
Is tension and reaction force constant in circular motion?
No, tension and reaction force are not constant in circular motion. They vary depending on the speed and radius of the circular motion, as well as any other forces acting on the object. However, they are always equal in magnitude and opposite in direction to each other, as required for circular motion.
