Tension between two objects moving at constant velocity
In summary: The tension is basically the force exerted by the engine on the trucks.In summary, the tension in the coupling between the railway engine and the leading truck is 1.6 kN when the train has an acceleration of 0.020 ms-2. When the train is moving at a constant velocity, the tension is zero. This is because according to F=ma, if the acceleration is zero, the force is also zero. Therefore, there is no tension in the coupling between the engine and the leading truck. The simplified calculation for finding the tension is to just calculate the force of the attached part (in this case the trucks) and it would be the tension.
moenste
711
A railway engine of mass 100 tonnes is attached to a line of trucks of total mass 80 tonnes. Assuming there is no resistance to motion, find the tension in the coupling between the engine and the leading truck when the train: (a) has an acceleration of 0.020 ms-2, (b) is moving at constant velocity.
Answers:
(a) 1.6 kN, (b) zero
F = ma
Weight = mg
(a) Ftotal = (100+80)*103 * 0.02 = 3600 N
Fengine = 100*103 * 0.02 = 2000 N
T = 3600 - 2000 = 1600 N
(b) Constant velocity = 0 acceleration. But I don't quite understand why there is 0 tension. Any tips? Thank you.
What else would you expect?
Zero acceleration is just a special case for F=ma, if acceleration is zero the force is zero as well.
You can simplify the calculation for (a) by the way, there is no need to consider the engine mass.
Likes moenste
Thank you. So in general, just calculate the F of the attached part (in this case the trucks) and it would be the tension: F = 80*103 * 0.02 = 1600 N. And if a = 0 then F = 80*103 * 0 = 0. I got you words correctly?
In general, you have to see what pulls what in which way.
In this case: yes, right.
Likes moenste
Related to Tension between two objects moving at constant velocity
1. What causes tension between two objects moving at constant velocity?
The tension between two objects moving at constant velocity is caused by an external force acting on one or both of the objects. This force can be applied through a physical connection, such as a rope or cable, or through a non-contact force, such as gravity or electromagnetic forces.
2. How does the tension affect the motion of the objects?
The tension between two objects moving at constant velocity can affect the motion of the objects in different ways. If the tension is equal on both objects, it will not change their velocity. However, if the tension is unequal, it can cause the objects to accelerate or decelerate depending on the direction of the force.
3. How is tension calculated between two objects?
Tension is calculated by multiplying the mass of the object by its acceleration. In the case of two objects moving at constant velocity, the tension can be calculated by finding the difference between the forces acting on each object and using Newton's second law (F=ma) to determine the tension.
4. Can tension exist between two objects if they are not physically connected?
Yes, tension can exist between two objects even if they are not physically connected. This is because non-contact forces, such as gravity or electromagnetic forces, can cause tension between objects without a physical connection. For example, the gravitational force between the Earth and the Moon causes tension between the two objects.
5. How does changing the velocity of one object affect the tension between two objects?
If one object's velocity is changed, it can affect the tension between the two objects. If the object's velocity increases, the tension will also increase, and if the object's velocity decreases, the tension will decrease. This is because the acceleration of the object will change, which in turn will affect the tension according to Newton's second law (F=ma).
10K
