x^2
- 21
- 1
The diagram shows a simple pendulum consisting of a mass M suspended by a thin, massless string. The magnitude of the tension is T. The mass swings back and forth between +/- theta_0. Which of the following are true statements?
A. T is the largest at the bottom (theta = 0 deg).
B. T = Mg at some angle between zero and theta_0.
C. The vertical component of tension is constant.
D. T equals Mg when theta = theta_0
E. T is greater than Mg when theta = theta_0
F. T is smallest when theta = +/- theta_0
T = (mv^2)/r + mg
Using the above equation, the tension should be greatest at the bottom of the swing (v reaches it's maximum) and a minimum at +/- theta_0 when v = 0. Therefore:
True: This is where v reaches a maximum so the tension will be maximum.
False: T = Mg only when (mv^2)/r = 0, which occurs at theta_0.
True: The vertical component is Mg which remains constant.
True: v = 0 so T = m0^2/r + Mg ==> T = Mg
False: Can't be true if T = Mg from above statement
True: There is no velocity at +/- theta_0, so this is where T must be a minimum.
I've tried the above answer set, also with C as false (I wasn't sure if maybe the vertical component related to more than just Mg), but both attempts were wrong. If my pendulum tension equation accurately describes the above scenario, I'm not sure where I went wrong in my reasoning.
Thanks,
x^2
