Tension Force problem involving friction
In summary: So in summary, we can find the maximum tension force for which the box doesn't slip by using the formula Ff = mu x n and applying Newton's 2nd law twice to find the maximum acceleration of the sled. This gives us a maximum tension force of 73.5 N.
chimbooze
1. A horizontal rope pulls a 20kg wood sled across frictionless snow. A 5 kg wood box rides on the sled. The coefficient of static friction for wood on wood is 0.5. What is the largest tension force for which the box doesn't slip?
m = 5 kg box, 20 kg sled
mu = .5
T = ?
2.
F = ma
Ff= mu x n
3.
F = ma
a of box is zero since it is not moving
T - mu x (20 + 5) x (9.8) = 0
No, both sled and box are accelerating. (They're being pulled by a rope.)
Hint: What is the maximum static friction between box and sled?
I partially get it. If Tension force is greater than the static friction force, then the box will move. So just find friction force.
Ff = mu x n
Ff = .5(9.8)(5)
But that isn't the right answer.
That's just one step toward the answer. Now that you know the maximum friction force on the box, what is the maximum acceleration that the sled can have without the box slipping?
To get the final answer, you'll need to apply Newton's 2nd law twice.
So:
sum of F = ma
Ff = ma
.5(9.8)(5) = 5(a)
a = 4.9
Tension of rope: T = ma
T = (10 + 5)(4.9)
T = 73.5
Thanks a lot. I got it correct.
Excellent!
Related to Tension Force problem involving friction
What is tension force?
Tension force is the force that is transmitted through a string, rope, cable, or any other type of flexible or stretchable material when it is pulled taut by forces acting from opposite ends.
How is tension force related to friction?
In a tension force problem involving friction, the tension force is affected by the coefficient of friction between two surfaces in contact. This coefficient determines the amount of frictional force that opposes the motion of the objects connected by the string or rope.
What factors affect the tension force in a frictional situation?
The tension force is affected by the magnitude of the applied force, the angle of the string or rope, the coefficient of friction, and the mass of the objects connected by the string or rope.
What is the difference between static and kinetic friction in a tension force problem?
Static friction occurs when two surfaces are in contact and not moving relative to each other, while kinetic friction occurs when there is relative motion between the two surfaces. In a tension force problem, static friction plays a role in determining the tension force required to move the objects, while kinetic friction affects the acceleration of the objects.
How can tension force problems involving friction be solved?
Tension force problems involving friction can be solved using Newton's laws of motion and the equations of static and kinetic friction. It is important to draw a free body diagram to identify all the forces acting on the objects and use equations to find the unknown variables.
