Tension in a rope holding a mass under a helicopter rising at constant speed
In summary: Perhaps there is a misunderstanding. In summary, we discussed the tension in a helicopter's rope as it accelerates up and down, and how this relates to the helicopter's weight and acceleration. We also briefly touched on the concept of a helicopter in a vacuum and its maximum speed. However, this question may be more complicated than a simple non-relativistic mechanics exercise.
John Mcrain
435
28
Tension in rope,constant speed
F=ma
Helicopter lift weight of 500kg ,weight is connect with load cell to meassure tension.
Neglect aerodynamic drag..
If helicopter accelarate up ,tension is rope is greater than 500kg.
If helicpter accelarate down ,tension is rope is less than 500kg.
If helicopter fly up with constant speed ,tension is rope is 500kg.
If helicopter fly down with constat speed tesnion in rope is 500kg
Am I correct?
Yes. Although, tension is measured in Newtons, not kilograms.
Likes hutchphd
PeroK said:
Yes.
What will be max velocity of helicopter when fly up if there is no aero drag force(vacuum)?
First of all, m=500 kg is a mass, not a weight. If you suppose g = about 10 m/s^2 , the weight is 5 kN .
If the helicopter accelerates up, the tension in the rope iincreases , because T -mg =ma —> T =m(g+a) .
The opposite happens when it accelerates down, write yourself the second equation of dynamics. But be careful, T is always directed from the mass toward the helicopter.
So, if a=0 the speed is costant , and the tension doesn’t change.
Likes PeroK
Yes I must write mass instead weight..
(if neglect air drag)
So if helicopter fly up with 5km/h or 5000km/h tension in rope in both case is 5kN?
What will determine max speed when helicopter fly up if there is no aero drag(vacuum)?
Trick question. A helicopter can't work in a vacuum
Likes Delta2
Ok let's say it has rocket propulsion..
A rocket can go as fast as you want (ask the Apollo folks) until Einstein intervenes. The ordinary Helicopter will have some speed of sound issues
So if helicoter weight is 5kN and helicoter max lift is 6kN(rocket propulsion),helicopter will accelarate to speed of light if there is no aero drag,only gravity force?
It will go fast. Einstein says it will not get to speed of light. In practice it will not get even close because of fuel required.
Yes but it doesn't metter how much thrust it has, 5.1kN or 5 000 000 kN,in both case will try to reach the speed of light.?
Yes. More thrust just speeds up the process. But rockets provide constant force. This is actually different from a propeller because the air is involved. The rocket doesn't care...it does not "push on the air".
Answer the question by @PeroK, first. He asked you: " What will be max velocity of helicopter when fly up if there is no aero drag force(vacuum)?” Maybe the rope has a breaking load that can’t be overcome? What this breaking load limits, in this problem?
Please, do not speak of relativity and speed of light every now and then, this is a very simple exercise of non relativistic mechanics!
@Steve, it is less tricky than what you imagine. It is logical that a helicopter works in air, the blades move down air with their rotation, and for reaction the helicopter stays up. Don’t introduce complications where they are not. The friction that is supposed to be possibly neglected is that on the suspended mass and the rope, we don’t care of the helicopter.
@John
without doubt, starting from rest the helicopter has to reach the speed you suggest, i.e. 5000 km/h , so it must accelerate for a while...But the problem is : is the rope able to sustain the over-tension caused by that acceleration ? Will it not break before? Answer the question by Perok.
PeroK didnt ask me any question,where are you looking at?
Please stop telling folks what to do.
The OP was just indicating his knowledge of the fundamental speed limit.
What is your answer to @PeroK question? I believe it is quite complicated for a real helicopter..
I can confirm that I have not asked a question in this thread!
Likes hutchphd
I believe the question was in fact posed by @John Mcrain and I perpetuated the mistake...vis "how fast can the helicopter go" Apologies.
Sorry @PeroK, question in #3 was not asked by you.
I’m not telling folks. Do what you want, but I repeat that this is a simple exercise of non-relativistic mechanics.
italicus said:
Sorry @PeroK, question in #3 was not asked by you.I’m not telling folks. Do what you want, but I repeat that this is a simple exercise of non-relativistic mechanics.
Manifestly not so for the OP.
now with incluced aero drag
So if we have box that fall in sky,inside is 50kg rock hanging on rope.
First box start to accelarate with accelaration little bit less then 1G because of air drag,so tension in rope will not be 100% zero,but close to zero..
When falling box reach constant speed let say 300km/h,tension at rope will be 50kg x 10=500N
Is there a question hidden in here? The air drag is typically modeled as ##\alpha v^2##. Is there an end point to this?
John Mcrain said:
When If falling box reach constant speed let say 300km/h,tension at rope will be 50kg x 10=500N
For a hypothetical infinitely tall uniformly dense atmosphere and an infinitely tall uniform gravitational field, 300 km/h will never be reached. Instead, it will be approached asymptotically.
Yes, in this case, tension will approach 500 N.For a hypothetical finitely tall [it has ground at the bottom] uniformly dense atmosphere and an infinitely tall uniform gravitational field, 300 km/h will never be reached. Instead, the ball will hit the ground first.
No, in this case tension will not approach 500 N.For a hypothetical atmosphere with an exponentially increasing density as altitude decreases and a much more nearly constant gravitational field the terminal velocity will be a decreasing function of altitude. It is possible in this case for a free-fall-with-drag trajectory to be initially below terminal velocity and to then pass through and beyond terminal velocity [or, more aptly, for terminal velocity to pass below fall velocity]. It is also possible for the falling box to impact the surface before this milestone has been reached.
Yes, if terminal velocity is reached, tension will [momentarily] hit 500 N exactly.
Related to Tension in a rope holding a mass under a helicopter rising at constant speed
What is tension and why is it important in a rope holding a mass under a helicopter?
Tension is the force applied by a rope to an object it is holding. In the case of a helicopter, the rope is holding a mass and the tension is what keeps the mass suspended. It is important because it determines the stability and safety of the object being held.
How does tension change as the helicopter rises at a constant speed?
As the helicopter rises at a constant speed, the tension in the rope remains constant. This is because the upward force of the helicopter's lift is equal to the downward force of gravity acting on the mass, resulting in a balanced tension in the rope.
What factors affect the tension in the rope?
The tension in the rope is affected by the weight of the mass being held, the speed at which the helicopter is rising, and the angle at which the rope is being pulled. These factors all contribute to the overall force being applied to the rope.
Can the tension in the rope ever be greater than the weight of the mass?
Yes, the tension in the rope can be greater than the weight of the mass if the helicopter is accelerating upwards. In this case, the force of the helicopter's lift will be greater than the force of gravity, resulting in a greater tension in the rope.
What happens to the tension in the rope if the helicopter suddenly stops rising?
If the helicopter suddenly stops rising, the tension in the rope will decrease. This is because the upward force of the helicopter's lift will no longer be present, resulting in a decrease in tension as the force of gravity pulls the mass downwards.
11K
