Tension in a String/Rope (tug-of-war)
  • Thread starter kartis
  • Tags
    Tension
In summary, the conversation discusses the use of Newton's second and third law to solve for the tension in a rope being pulled by two students. The students' acceleration is calculated using the equation Fnet = m*a, and the tension is found using the equation T = F - ma. However, there is confusion about the forces acting on the students from the ground and whether the problem is solvable due to an unbalanced force on the rope. The conversation ends with a suggestion to create a free-body diagram for a tug-o-war to better understand the problem.
kartis
Two students are having a tug of war. A 60kg student pulls on a rope with a force of 40N to the left. A 70kg student pulls on the other end of the rope with a force of 50N to the right. Find the
a) acceleration of the two students
b) force of tension in the rope
Newton's Third Law
a) I think you can just use Fnet = m*a, so for
student 1: a = 40N/60kg a = 0.667 m/s^2
student 2: a = 50N/70kg → a = 0.714 m/s^2
b) Fnet = F - T, rearrange to solve for tension, → T = F - ma
Student 1, T = 40N - (60kg*0.667m/s^2) T = -0.02N
Student 2, T = 50N - (70kg*0.71m/s^2) T = 0.02N
The answer seems wrong since its too small. From my understanding the force of tension of the rope needs to be equal on both sides of the rope. But I'm not sure if that also applies to different applied forces on both ends. The answers to the question aren't given.
Where did you get this question?
What happens if you apply Newton's second law to the rope?
Likes hutchphd
The teacher gave it for practice.
I think I've used the equations from the second law throughout the question. The only thing applied from Newton's third law could be that since every action force has an equal reaction force, the tension would be equal on both ends of the rope.
What did you use for the mass of the rope?
The mass of the rope isn't given. So i assume you can only find the tension after you've calculated the acceleration of the students.
Okay, what about the forces on the two students from the ground, where they are no doubt pushing with their feet?
I should say that I think the question is nonsense. Which is why I asked where you found it.
  • Haha
Likes kartis
If they're pushing on the ground, that means the ground may be creating friction helping them each to move to the left or right, but I believe the student with the greater acceleration wins? I feel like there's multiple ways to do this problem that I can't wrap my head around.
Lol i guess having a phd doesn't make my teacher any smarter XD
If you apply Newton's second law to the rope, then you have an unbalanced force of ##10N## on the rope, so there will be acceleration of the rope. That's the only way there can be an unbalanced force on the rope.
The students don't accelerate from the force on the rope alone: they also have forces on them from the ground.
I'm not sure whether whoever set the problem had no idea about any of this.
Likes etotheipi
I think I understand now, thanks. But how will we solve that with the equations? Can I still use Fnet = m*a? Or do I just figure it out by recognizing the forces are unbalanced, so the rope would move in the direction of the unbalanced force?
You could do a general free-body diagram for a tug-o-war. That's worth doing.
Likes kartis
Thank you for you help!
Only if you use the right m. As @PeroK has indicated, it would be the mass of the section of rope between them, which is unknown. If it has mass 1kg then it will be accelerating at roughly g. Even then, you wouid not be able to state "the tension" since it will vary along the rope, from 40N at one end to 50N at the other.
Either this is a trick question (to which the correct answer is "not enough info") or the setter has blundered. Consider a slightly different question:
One end attaches to a 56kg mass lying on a smooth horizontal surface, and on the other side of that mass a second rope goes over a pulley to a suspended 4kg mass: 56+4=60.
The other end attaches to a 65kg mass, thence by another rope to a suspended 5kg mass: 65+5=70.
While something in the middle holds everything static, there is a tension of 40N at one end and 50N at the other. But as soon as the system is released it will accelerate and the tension in the central rope will become some value between the two.
Sounds like the intended question, except that the two systems are now not pulling on the rope with different forces; each pulls with the same force, namely, the tension.
Likes kartis
Is it possible for there to be two different forces of tension on opposite ends if the rope is being pulled by forces with different magnitudes?
We had a long thread about this recently. For a static scenario, no - because of Newton's second law for the rope. The rope must accelerate if there is an unbalanced force on it. And, if you consider the rope to be of negligible mass, then the tension must be equal throughout the rope.
Likes kartis
And, to be absolutely clear, the forces with which the rope is being pulled are equal to this tension, so are themselves equal. That is the flaw in the question in this thread.
FAQ: Tension in a String/Rope (tug-of-war)
What is tension in a string/rope?
Tension in a string/rope is a pulling force that is created when two or more objects are connected by a string or rope and are pulled in opposite directions. It is also known as the force of tension.
How is tension in a string/rope measured?
Tension in a string/rope is measured in units of force, such as newtons or pounds. It can be measured using a spring scale or a force meter.
What factors affect the tension in a string/rope?
The tension in a string/rope is affected by the amount of force applied, the length of the string/rope, and the elasticity of the string/rope material. Other factors that can affect tension include the weight of the objects being pulled and any friction or resistance in the system.
How does tension in a string/rope affect the speed of an object?
Tension in a string/rope can affect the speed of an object by either accelerating or decelerating it. If the tension is greater than the opposing forces, the object will accelerate. If the tension is less than the opposing forces, the object will decelerate.
Can tension in a string/rope be used to calculate the force applied?
Yes, the tension in a string/rope can be used to calculate the force applied by using the formula F = T x cosθ, where F is the force applied, T is the tension in the string/rope, and θ is the angle between the string/rope and the direction of the force.
