Tension in a wire due to a standing wave
In summary, the tension on the 2m long steel wire with a diameter of 2mm and vibrating at a frequency of 392 Hz is 60247.16N.
moonkey
Question 8
A 2m long steel wire is mounted in an insulated bath of water containing 2000 litres of water.
(a) If the bath is a rectangle 2 m long and 1 m wide, what is the depth of the water
The wire vibrates with a fundamental frequency of the G above middle C (392 Hz). The velocity of
the wave on the wire is given by:
v = sqrt(T/μ);
where T is the tension, and μ is the mass per unit length of the wire.
(Ignore the whole thing about the water, it's to be used in subsequent parts of the question that I haven't posted)
(b) If the diameter of the steel wire is 2 mm, what is tension on the wire?
Density of Steel: ρ = 7.8 x 103 kg/m3.
v=sqrt(T/μ)=λf
λ=2L μ=ρV/L=ρπr2L/L=ρπr2
sqrt(T/ρπr2)=2Lf
T=4ρπr2L2f2
ρ=7.8x103 kg/m3, r=0.001m, L=2m, f=392Hz
T=(4)(7.8x103)(π)(0.001)2(2)2(392)2
T=60247.16N
Does this seem right? 60kN seems like a very large force.
Yes, your calculation appears to be correct. The tension on the wire would indeed be quite large due to the high density of steel and the small diameter of the wire. It's always a good idea to double check your calculations and units to make sure they are consistent.
Related to Tension in a wire due to a standing wave
1. What is a standing wave?
A standing wave is a type of wave that occurs when two waves of equal frequency and amplitude traveling in opposite directions interfere with each other. As a result, the waves appear to be standing still and do not move forward or backward.
2. How does a standing wave create tension in a wire?
A standing wave creates tension in a wire by causing the wire to vibrate at its resonant frequency. As the wave travels back and forth along the wire, it creates regions of high and low tension, resulting in standing nodes and antinodes. This tension is what allows the wave to sustain itself and creates the characteristic pattern of a standing wave.
3. What factors affect the tension in a wire due to a standing wave?
The tension in a wire due to a standing wave is affected by several factors, including the amplitude and frequency of the wave, the length and material of the wire, and the presence of any fixed boundaries or supports along the wire's length.
4. How is tension in a wire related to the wavelength of a standing wave?
The tension in a wire is indirectly related to the wavelength of a standing wave. As the wavelength of the wave increases, the distance between the standing nodes and antinodes also increases, resulting in a higher tension in the wire. Similarly, a shorter wavelength results in a lower tension in the wire.
5. Can tension in a wire due to a standing wave be manipulated?
Yes, the tension in a wire due to a standing wave can be manipulated by adjusting the factors that affect it. For example, changing the frequency or length of the wave can alter the tension in the wire. Additionally, adding or removing fixed boundaries along the wire can also impact the tension. This manipulation of tension can be useful in various scientific and engineering applications.
