Tension in string of object suspended in liquid
In summary, the conversation discusses the process of determining the tension in a string suspending an aluminum object in ethyl alcohol. The equations Fy = Fb + T - mg and T = mg - Fb are used to calculate the tension, with the help of the density and volume of the object and the fluid. The conversation also emphasizes the importance of including units in calculations to avoid mistakes.
javashackgirl
an aluminum object with volume 100 cm^3 and density 2700 kg/m^3 is suspended in ethyl alcohol (density 790) by a string. what's the tension in the string?
Fy = Fb + T - mg
T = mg - Fb
Fb = p_f * v_f * g = p_o * v_o * g
=(p_o - p_f)p_f*v_o*g
=(2700 - 790)(790)(1*10^-4)(9.81)
Thanks!
Not quite, check the units.
It might be simpler if you worked in some numbers.
Tension = weight down - boyancy up
mass = density * volume = 2700 kg/m^3 * 0.0001 m^3 = 0.27 kg
boyancy = weight of fluid = 790 kg/m^3 * 0.0001m^3 = 0.079 kg
So effective mass of block (0.27-0.079) = 0.191kg,
weight = 0.1919kg * 9.81 Newtons
i figured out what i did wrong. your way was much easier, thanks :)
Useful tip always put the units in your calculation or rearrangment of equations - it makes it much easier to spot any little 'opps'
Eg. to get mass from density.
kg = kg m^-3 * m^3 = kg !
I would first like to clarify the units used in the given information. The volume of the object is given in cubic centimeters (cm^3) while the densities are given in kilograms per cubic meter (kg/m^3). To ensure consistency, the volume should be converted to cubic meters (m^3) by dividing by 1,000,000. This gives a volume of 0.0001 m^3 for the object.
Using the given formula for buoyant force (Fb = p_f * v_f * g), we can calculate the buoyant force of the object in ethyl alcohol:
Fb = (790 kg/m^3) * (0.0001 m^3) * (9.81 m/s^2)
= 0.7749 N
Next, we can calculate the weight of the object using its mass (density * volume) and the acceleration due to gravity:
mg = (2700 kg/m^3) * (0.0001 m^3) * (9.81 m/s^2)
= 2.6517 N
Now, we can plug these values into the equation Fy = Fb + T - mg to find the tension in the string:
T = mg - Fb
= (2.6517 N) - (0.7749 N)
= 1.8768 N
Therefore, the tension in the string is approximately 1.8768 N. It is important to note that this is an ideal calculation and may differ in real-world scenarios due to factors such as air resistance and imperfections in the string.
Related to Tension in string of object suspended in liquid
1. What is tension in a string?
Tension in a string is the force that is applied to the string in order to keep it taut. It is a pulling force that acts in the direction of the string's length.
2. How does tension affect an object suspended in a liquid?
Tension in a string can affect an object suspended in a liquid in several ways. It can help to support the weight of the object and keep it suspended. It can also help to stabilize the object and prevent it from moving too much in the liquid. Additionally, tension can help to create a balanced system where the forces acting on the object are equal.
3. What factors affect the tension in a string of an object suspended in a liquid?
The tension in a string can be affected by several factors, including the weight of the object being suspended, the properties of the string such as its length and material, and the density of the liquid. The depth and temperature of the liquid can also impact the tension in the string.
4. How is the tension in a string of an object suspended in a liquid calculated?
The tension in a string can be calculated using the formula T = mg + ma, where T is the tension, m is the mass of the object, g is the acceleration due to gravity, and a is the acceleration of the object in the liquid. This formula takes into account the weight of the object as well as any additional forces acting on it.
5. Can the tension in a string of an object suspended in a liquid change over time?
Yes, the tension in a string can change over time. Factors such as changes in the weight of the object, the properties of the string, and the conditions of the liquid can all affect the tension. Additionally, if the object is moving or experiencing acceleration in the liquid, the tension in the string may also change.
