Tension in Strings Supporting AB Bar: Calculating Weight & Mass
In summary, the conversation discusses a uniform bar supported in a horizontal position by two vertical strings, with one string at 0.5m from point A and the other at 1.5m from point B. The tensions in the strings are found to be 40N and 20N respectively, and to keep the bar horizontal, an additional weight of 15N must be applied at point A. The maximum weight that can be hung from point B without causing the bar to tilt is 40N.
chanella35
1.AB is a uniform bar of length 5m and weight 60N. It is supprted in a horizontal position by 2 vertical strings P and Q. P is 0.5m from A
and Q 1.5m from B.
a) What are the tensions in the strings?
b) What weight must be applied at A if the tensions in the strings are to be equal?
c) What is the biggest mass which can be hung from B if the bar is to remain horizontal? please help...i got a) but I am not sure about b and c
this h.w is for 5 extra points on a test on monday if i get them right...please help.
and Q 1.5m from B.
c) What is the biggest mass which can be hung from B if the bar is to remain horizontal? a) M(P) :
3*q -2*60 = 0
3q-120=0
q=40
[resolving vertically upwards]:
p+q-60=0
p+40-6=0
p-20=0
p=20
b) finding P:
60-4.5p+5F=0
(-40 + 2p-2.5F=0)*2
60-4.5p + 5F= 0
-80 + 4p-5F=0
-20 + .5p = 0
.5p = 20
p = 20/.5
p= 40Nfinding F:
40-60+40-F = 0
20-F=0
F=20N
M(F):
B-40+60-40+20=0
B= 0
? i don't know if these are right...i tried. Please help me.
You draw all the forces and in each case you write down the following two equations:
Total force up=Weight
Total torque counterclockwise about center of mass=0
(you have to pay attention to the *signs* since the forces are taken "up" as positive and the torque "counterclockwise" about the center as positive [you can also chose clockwise if you like, but at least all torques in the *same* direction about the center of mass])
The torque is (distance from center of mass) times (perpendicular force in counterclockwise direction). For example if the force on string P is called P and string P is 2m from the center of mass, then the torque is -2*P (negative since its not counterclockwise as we agreed). Likewise Q is 1m from the center so the torque is 1*Q.
a)
forces and torque equations:
P+Q=60
-2*P+1*Q=0
Solve this set of equations and get P=20N and Q=40N
b)
again forces and torque this time with a new force A at point A (and distance 2.5 from center):
P+Q-A=60
2.5*A-2*P+1*Q=0
and P and Q should be equal so
P=Q
Solving these equations (use P=Q first to get rid of Q and continue) you get
A=15N and P=Q=37.5N
c)
this time the extra force is B at B:
P+Q-B=60
-2*P+1*Q-2.5*B=0
for the bar to stay horizontal you want string P to pull and not push (which a string can't do). so
P>0
canceling Q in the first two equations you get an equation for P and pluging this in into the last you get
20-0.5*B>0
This corresponds to
B<40N
which is the maximum weight you can apply at B.
Thanks so much :D:D:D
FAQ: Tension in Strings Supporting AB Bar: Calculating Weight & Mass
How is the tension in strings supporting an AB bar calculated?
The tension in strings supporting an AB bar can be calculated by using the formula T = mg, where T is the tension, m is the mass of the object, and g is the acceleration due to gravity (9.8 m/s^2). This formula assumes that the strings are in equilibrium, meaning that the forces acting on the AB bar are balanced.
What factors affect the tension in strings supporting an AB bar?
The tension in strings supporting an AB bar can be affected by several factors, including the mass of the object, the angle at which the strings are attached to the bar, and any external forces acting on the bar (such as wind or other objects).
How is weight related to tension in strings supporting an AB bar?
Weight and tension are directly related when it comes to strings supporting an AB bar. The weight of the object will determine the tension in the strings, as shown by the formula T = mg. This means that as the weight of the object increases, the tension in the strings will also increase.
How do you calculate the mass of an object using the tension in strings supporting an AB bar?
To calculate the mass of an object using the tension in strings supporting an AB bar, you can rearrange the formula T = mg to solve for m. This will give you the mass of the object in kilograms. Keep in mind that this calculation assumes that the strings are in equilibrium, and may not be accurate if there are external forces acting on the bar.
What is the significance of calculating tension in strings supporting an AB bar?
Calculating the tension in strings supporting an AB bar is important because it helps us understand the forces acting on the bar and how they are balanced. This information can be used in various applications, such as engineering and physics, to ensure the stability and safety of structures.
