Tension on A Rope of Negligible Mass
In summary: I sincerely apolozise if you feel i have hijacked the thread.I thought that the OP's concern has been addressed.
Bashyboy
1,421
I was a reading a little section in my physics textbook regarding tension in a flexible cord. There is a part in the paragraph that I am not sure why is true. It goes as follows: "When a flexible cord pulls on an object, the cord is said to be under tension, and the force it exerts on an object...[can be the tension]...FT. If the cord has negligible mass, the force exerted at one end is transmitted and undiminished to each adjacent piece of cord along the entire length to the other end." Could someone explain to me why the second sentence is true? Thank you.
If the cord has negligible mass and acceleration is finite then the net force on the cord must be zero (ma = 0). Therefore tension on the two ends will be equal and opposite.
I am not sure I really understand that explanation, sorry.
Try looking at it this way. When a mass is hung from the string, the lowermost molecule of the string is tugged by the gravitational force acting on the suspended object. This molecule passes on the 'tug' to its adjacent upper molecule, and as it is assumed to be massless, it does this without loss of force in transmission. This tug on the second molecule is passed on to the third and so on.. Finally the uppermost molecule of the string, immediately in contact with the roof experiences this pulling force and since it has no other molecule of its own to pass on this force, it transmits this to the roof, thereby pulling the roof with the exact same force the mass was being pulled at.
Suppose the tension at the two ends is not the same. That would mean there is a force acting on a mass that is very close to 0. If that was the case since F = ma, the string would experience an infinite acceleration. Since this doesn't happen, the tension is either the same at both ends or the difference is so small that we can ignore it.
I understand that this thread is rather old, but I recently have come across this difficulty again. I understand Infinitum's argument to some extent, but I am wondering if there is some mathematical way of showing it. If the rope is massless, then molecules that constitute it are massless, and the force transmits from one molecule to the next, is there a mathematical way of showing this?
You can try thinking of the rope as a chain of massless beads connected to one another by short massless springs. Now we can set up a free-body diagram for any given bead and use ##F=ma## to see what the forces on it are; the tension in the spring is the tension of the rope at that point.
Interestingly, this approach works whether the rope is massless or not. If the rope has mass you just have to assign a suitable mass to each bead.
Hi Nugatory
Consider a massless string going over a massless frictionless pulley with masses M1 and M2 at the end of the string.
The tension in the string would be same.
The torque equation of the pulley says (T1-T2)=Iα .Now L.H.S is zero since T1=T2 and also I=0 .
So,we have a condition 0=(0)(α) which makes α indeterminate .But we know that the pulley rotates.
So ,how is α determined ?
Is α=a/R where R is the radius of the pulley and a=[(M2-M1)g]/(M1+M2) ?
Tanya Sharma said:
Hi Nugatory
Consider a massless string going over a massless frictionless pulley with masses M1 and M2 at the end of the string...
that's a different problem than OP posed. Rather than hijacking his thread, it might be best to start a new one.
I sincerely apolozise if you feel i have hijacked the thread.I thought that the OP's concern has been addressed .i had doubt somewhat related so posted here .
Sorry,once again .
FAQ: Tension on A Rope of Negligible Mass
What is tension on a rope of negligible mass?
Tension on a rope of negligible mass refers to the force applied by the rope when it is stretched or pulled. It is a measure of the internal forces within the rope, and it is typically represented by the symbol T.
Why is the mass of the rope considered negligible?
The mass of the rope is considered negligible because it is assumed to be so small that it does not significantly affect the overall tension in the system. This allows for simpler calculations and models in situations where the rope is not the main focus of the analysis.
How is tension calculated on a rope of negligible mass?
Tension on a rope of negligible mass can be calculated using the formula T = F/a, where T is the tension, F is the applied force, and a is the cross-sectional area of the rope. This formula assumes that the rope is in equilibrium, meaning that the net force acting on it is zero.
What factors can affect the tension on a rope of negligible mass?
The tension on a rope of negligible mass can be affected by factors such as the applied force, the angle at which the force is applied, and any external forces acting on the rope. The stiffness and length of the rope can also impact the tension.
Why is tension on a rope of negligible mass important in scientific research?
Tension on a rope of negligible mass is important in scientific research because it is a fundamental concept in mechanics and is often used in various applications such as engineering, physics, and biology. Understanding tension can help researchers design and analyze systems involving ropes, cables, and other similar structures.
22K
