Tensor Calculations given two vectors and a Minkowski metric
The discussion centers on tensor calculations involving two vectors, A and B, and a Minkowski metric. Participants analyze the expressions A^νB^μ, A^νB_μ, and A^νB_ν, clarifying that A^νB^μ results in a coordinate-dependent scalar rather than a tensor. They agree that A^νB_μ can be interpreted as a tensor expression, while A^νB_ν yields a scalar that is independent of coordinates. The conversation highlights the importance of understanding how vector components transform under Lorentz transformations in relation to the Minkowski metric.
Arman777
Insights Author
Calculating tensor equations
Tensor Identities
Let us suppose we are given two vectors ##A## and ##B##, their components ##A^{\nu}## and ##B^{\mu}##. We are also given a minkowski metric ##\eta_{\alpha \beta} = \text{diag}(-1,1,1,1)##
In this case what are the
a) ##A^{\nu}B^{\mu}##
b) ##A^{\nu}B_{\mu}##
c) ##A^{\nu}B_{\nu}##
For part (a), it seems that we are going to obtain a 4x4 matrix with components
$$A^{\nu}B^{\mu} = \begin{bmatrix}
A^0B^0 & ... & A^0B^3 \\
A^1B^0 & ... & A^1B^3\\
A^2B^0 & ... & A^2B^3 \\
A^3B^0 & ... & A^3B^3\\
\end{bmatrix}$$
For part (b) I have written something like this
$$A^{\nu}B^{\gamma}\eta_{\mu \gamma} = D^{\nu}_{\mu} =
\begin{bmatrix}
A^0B^0\eta_{00} & A^0B^1\eta_{11} & A^0B^2\eta_{22} & A^0B^3\eta_{33}\\
A^1B^0\eta_{00} & A^1B^1\eta_{11} & A^1B^2\eta_{22} & A^1B^3\eta_{33}\\
A^2B^0\eta_{00} & A^2B^1\eta_{11} & A^2B^2\eta_{22} & A^2B^3\eta_{33}\\
A^3B^0\eta_{00} & A^3B^1\eta_{11} & A^3B^2\eta_{22} & A^3B^3\eta_{33}\\
\end{bmatrix}$$Actually the ##D^{0}_{0}## becomes ## = A^0B^0\eta_{00} + A^0B^1\eta_{01} + A^0B^2\eta_{02} + A^0B^3\eta_{03}## but that is just ##A^0B^0\eta_{00}##
For part c its just the sum I guess so I need to write
##A^{\nu}B_{\nu} = A^{\nu}B^{\gamma}\eta_{\nu \gamma} = A^0B^0\eta_{00} + A^1B^1\eta_{11} + A^2B^2\eta_{22} + A^3B^3\eta_{33}##
Are these expressions ttrue ?
If I do something like this
##B_{\mu} = \eta_{\mu \nu}B^{\nu}## and write ##B_{\mu} = (-B^0, B^1, B^2, B^3)## and just multiply this with ##A^{\nu}## I would have got the same result right ?
Likes vanhees71
c) ##A^{\nu}B_{\mu}##
(c) is identical to (b). I think you must have written one of them down wrong.
I think (a) gives a coordinate-dependent scalar, not a matrix, as it simply represents the product of
##A^{\nu}## (a scalar, as it is a component of A) with ##B^{\mu}## (a scalar, as it is a component of B). I have not come across any tensor notation that allows interpretation of ##A^{\nu}B^{\mu}## as a tensor expression.
We can however interpret ##A^{\nu}B_{\mu}## as a tensor expression, and it aligns with the second matrix you show above - which you label as (a) but I think you meant (b).
For (c), later in your post you rewrite it as different to what you write at the top. I agree with the solution you give for that - a sum that returns a scalar - in this case also a 0-0 tensor (ie coordinate-independent), as we can interpret your correction of (c) as a tensor expression.
To your last question, I would say Yes, assuming you're asking about (b), and you have to use an index different from ##\nu## as the second index of the Minkowski tensor. I would write:
$$A^{\nu}B_{\mu} = A^{\nu}\left(B^{\gamma} \eta_{\mu\gamma}\right)$$
Likes vanhees71 and Arman777
I have edited my post maybe you can do the same
Aν (a scalar, as it is a component of A) with Bμ (a scalar, as it is a component of B). I have not come across any tensor notation that allows interpretation of AνBμ as a tensor expressio
This is interesting. But I cannot understand how can it give us a scalar ?
Let me write ##A^{\nu}B^{\mu} = A^{\nu}B_{\gamma}g^{\mu \gamma}##
##A^{\nu}B_{\gamma}## This is the same as ##D^{\nu}_{\gamma}## so it seems that my result is correct.
By definition, a scalar is a quantity, which doesn't change under Lorentz transformations. I'm a bit puzzled, what the correct question c) is. If it's ##A_{\nu} B^{\nu}## it means, as was also said before ##\eta_{\mu \nu} A^{\mu} B^{\nu}## (note that you have to sum over repeated indices from 0 to 3).
Now think, how do vector components like ##A^{\mu}## and ##B^{\nu}## transform under a Lorentz transformation, and what it actually means that a transformation is a Lorentz transformation (in relation to the Minkowski "metric").
Its just ##A^{\alpha}\Lambda^{\bar{\beta}}_{\bar{\alpha}}= A^{\bar{\beta}}##
where
$$\Lambda^{\bar{\beta}}_{\bar{\alpha}} =
\begin{bmatrix}
\gamma&-v\gamma&0&0\\
-v\gamma&\gamma&0&0\\
0&0&1&0\\
0&0&0&1
\end{bmatrix}$$
What do you think either of those expressions mean? Try to express it in terms of vectors A, B and the metric ##\eta## without using subscripts - ie in coordinate-independent language. You won't be able to, which indicates that the expression is coordinate-dependent.
By contrast, I can express (b) as vector A applied to the covector of B given a metric ##\eta##, and (c) as the trace of (b). These are coordinate-independent descriptions.
where
\begin{bmatrix}
0&0&1&0\\
0&0&0&1
\end{bmatrix}$$
Good! And what follows then for ##A_{\alpha} B^{\alpha}## and ##A_{\bar{\alpha}} B^{\bar{\alpha}}##? (NB I don't like to put the basis-distinguishing label to the indices of tensor components but put it on the symbol, i.e., I'd rather write
$$A^{\prime \beta}={\Lambda^{\beta}}_{\alpha} A^{\alpha}.$$
Also note that you should carefully keep both the horizontal and the vertical placement of the indices under control!
