MHB Tensor Products - D&F - Extension of the scalars
Math Amateur
MHB
I am attempting to understand Dummit and Foote exposition on 'extending the scalars' in Section 10.4 Tensor Products of scalars - see attachment - particularly page 360)
[I apologise in advance to MHB members if my analysis and questions are not clear - I am struggling with tensor products! - anyway, I hope readers can divine what I am on about :) ]
On page 360, D&F write the following:
If the R-module N were already a an S-module then there is no difficulty in "extending" the scalars from R to S, so we begin the construction by returning to the basic module axioms in order to examine whether we can define "products" of the form sn, for $$ s \in S $$ and $$ n \in N $$. These axioms start with an abelian group N together with a map from S x N to N, where the image of the pair (s,n) is denoted sn. It is therefore natural to consider the free $$ \mathbb{Z} $$-module (i.e. the free abelian group) on the set S x N i.e. the collection of all finite commuting sums of elements of the form $$ (s_i, n_i) $$ where $$ s \in S $$ and $$ n \in N $$. ... ... etc etc
I would like someone to confirm (or correct) my statements and reasoning in the following ...
An abelian group on the set S x N would be an additive group, with an operation + defined componentwise, visually:
$$ (s_1, n_1)+ (s_2, n_2) = (s_1 + s_2, n_1 + n_2) $$ ... ... (1)
which seems OK since S is a ring and N is a module and so the two compnent + operations on the right of (1) above are OK. The operations + are associative, identity is (0,0), inverse of (s, n) is (-s, -n). Is that correct?
Now D&F write (see attachment or above)
"t is therefore natural to consider the free $$ \mathbb{Z} $$-module (i.e. the free abelian group) on the set S x N ... ..."
Now I am uncertain about how to form the free $$ \mathbb{Z} $$-module on the set S x N ... but anyway, I followed D&F's example on page 339 ... ... (see attachment)
Following D&F's example (where $$ R = \mathbb{Z} $$ ? ... in our case $$ R \ne \mathbb{Z} $$ , but continuing anyway ...) ... ...
Make the abelian group into a $$ \mathbb{Z} $$-module on the set S x N as follows:
For $$ m \in \mathbb{Z} $$ and (s,n) in S x N we define:
m(s,n) = (s,n) + ... ... + (s,n) (m times if $$m \gt 0 $$)
and
m(s,n) =0 if m = 0
and
m(s,n) = - (s,n) - ... ... - (s,n) (m times if $$m \lt 0 $$)
(and I take it that -(s,n) = (-s, -n) ...
But then, how do we (following what D&F say above) end up with elements of the free module being finite commuting sums of elements of the form $$ (s_i, n_i) $$ (i.e. elements of the form $$ \sum_i (s_i, n_i) $$ where the sum is finite?)
Do we actually "forbid" operations of addition of elements such as $$ (s_1, n_1)+ (s_2, n_2) = (s_1 + s_2, n_1 + n_2) $$? Can someone please clarify this matter?
Further, how does the map from S x N to N with the images sn come into the above construction ...
I would appreciate some help.
Peter
No.
You start with the set $S\times N$. But you do not define $(s_1,n_1) + (s_2,n_2) = (s_1+s_2,n_1+n_2)$. If you are doing that, you are doing it incorrectly. So how do you define addition? You basically just defined formal sums. In other words, you just keep $(s_1,n_1) + (s_2,n_2)$ without adding anything together. There is no component addition. It is just formal addition.
You start with $S\times N$ and then form $F(S\times N)$ this is the free abelian group generated by the set $S\times N$. So it consists of all formal sums.
Any abelian group can be regarded as a $\mathbb{Z}$-module by defining $ng = g+g+...+g$ and with negatives if $n$ is a negative integer. Now since $F(S\times N)$ is an abelian group it can now be regarded as a $\mathbb{Z}$-module in the sense just explained above.
ThePerfectHacker said:
No.
Thanks, your post is most helpful!
Peter
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
