Tensor Products - Keith Conrad - Theorem 3.3 - Tensor Products I
In summary, the conversation is about Conrad's paper on tensor products and the importance of Theorem 3.3 in defining elementary tensors in the tensor product of R-modules M and N. The conversation then delves into the concept of spanning sets for modules and how they do not necessarily have to be finite. However, it is necessary for the number of non-zero elements in the linear combinations to be finite, as infinite sums do not make sense unless there is a notion of convergence. The conversation also touches on the idea of free objects and how a minimal spanning set should agree with the notion of a basis. Ultimately, the question is how to guarantee that for elements m and n from M and N, we can write them as finite linear combinations
Math Amateur
MHB
3,998
48
I am reading and trying to fully understand Keith Conrad's paper: Tensor Products I. These notes are available at Expository papers by K. Conrad or the specific paper at http://www.math.uconn.edu/~kconrad/blurbs/linmultialg/tensorprod.pdf.
Conrad's Theorem 3.3 (see attachment - page 10) is important since it, to an extent at least, begins to define the nature of elementary tensors \(\displaystyle m \oplus n \) in the tensor product \(\displaystyle M \oplus_R N \) where M and N are R-modules.
Theorem 3.3 and its proof read as follows:
Theorem 3.3. Let M and N be R-modules with respective spanning sets with respective spanning sets \(\displaystyle \{ x_i \}_{i \in I} \) and \(\displaystyle \{ y_j \}_{j \in J} \).
The tensor product \(\displaystyle M \oplus_R N \) is spanned linearly by the elementary tensors \(\displaystyle x_i \oplus y_j \)
Proof: An elementary tensor in \(\displaystyle M \oplus_R N \) has the form \(\displaystyle m \oplus n \).
Write \(\displaystyle m = \sum_i a_ix_i \) and \(\displaystyle n = \sum_j b_jy_j \), where the \(\displaystyle a_i s \) and \(\displaystyle b_j s \) are 0 for all but finitely many i and j.
From the bilinearity of \(\displaystyle \oplus \) we have:
\(\displaystyle m \oplus n = \sum_i a_ix_i \oplus \sum_j b_jy_j = \sum_{i,j} a_ib_jx_i \oplus y_j \)
is a linear combination of the tensors \(\displaystyle x_i \oplus y_j \).
Since every elementary tensor is a sum of elementary tensors, the \(\displaystyle x_i \oplus y_j 's \) span \(\displaystyle M \oplus_R N \) as an R-module.
Now my issue/problem ...
In the above Conrad assumes that the R-modules M and N have spanning sets \(\displaystyle \{ x_i \}_{i \in I} \) and \(\displaystyle \{ y_j \}_{j \in J} \).
Do all modules have spanning sets? (they do not necessarily have bases - which is a similar concept - unless they are free modules, of course.)
Is this simply a case of taking more and more elements in the spanning set ... even up to all the elements of the module? But then how do we guarantee that for elements m and n from M and N that we can write:
Can someone please clarify this issue for me. I would appreciate guidance on this matter.
Peter
The spanning sets need not be finite (in fact, for many important examples, this will NOT be true).
For example, with $R[x]$, considered as an $R$-module, we see we have the infinite spanning set:
$\{1,x,x^2,\dots\}$.
In some cases, the spanning set may be almost all of $M$ (we can always leave out 0). This is the case, for example, for $\Bbb Z_2$, where the spanning set is the sole non-zero element.
And yes, $M\setminus\{0\}$ certainly spans $M$. So if that was the case, you would have $|M-1|\ast|N-1|$ elementary tensors. Usually, though, we have a much more modest generating set for $M$ (often we are interested in finitely-generated modules). In such a case (and I have a hard time imagining how this would occur, since for every element $x$ is the spanning set, we might have as many as $|R|$ distinct elements spanned by $\{x\}$) we certainly have $m \in M$ as the finite linear combination:
$m = 1m$.
$m = 1m$.
Thanks Deveno ... that helps ... but I am still puzzling over the question:
How do we guarantee that for elements m and n from M and N that we can write:
As you point out the spanning sets need not be finite, so how do we guarantee that the number of non-zero elements in the above sums is finite?
Can you help?
Peter
That is what spanning MEANS.
The idea is: a module consists of $R$-linear combinations of an abelian group. Linear combinations are by definition finite (an infinite sum doesn't mean anything unless you have some notion of convergence).
Now, to be fair, is IS possible to have such things as "formal power series" (where we consider "infinite linear combinations of $x^n$") which can be identified with the space of all functions:
$f: \Bbb N \to R$.
But we consider the free $R$-module on $R^{\infty}$ to be:
$\displaystyle \bigoplus_{\Bbb N} R$
instead of:
$\displaystyle \prod_{\Bbb N} R$
because the former is a lot SMALLER than the latter (we want "free objects" to be minimal, in some sense).
When $R = F$, a field, we want a minimal spanning set to agree with the notion of BASIS, and a basis consists of a $F$-linearly independent set such that any element of $V$ (an $F$-module) can be written as a FINITE $F$-linear combination of basis elements.
Recall that the $R$-module generated by a set $S$ is the SMALLEST $R$-submodule $N$ of a module $M$ such that $S \subseteq N$.
While it is certainly possible to consider "infinite $R$-linear combinations of $S$", the set of "finite $R$-linear combinations of $S$" has the closure properties:
finite + finite = finite
scalar(finite) = finite
so the set of finite $R$-linear combinations is clearly smaller, and also contains $S$.
For example, "finite power series" are polynomials, so $R[x]$ is the $R$-module generated by $\{x^n:n \in \Bbb N\}$, not $R[[x]]$.
This discussion can get rather tricky when considering "infinite copies of $R$" (as is the case, for example, when considering "infinite-dimensional vector spaces" such as the vector space of all functions:
$f: \Bbb R \to \Bbb R$
where finding a basis is clearly a difficult task).
I would like to point out that the concept of spanning sets is a fundamental idea in linear algebra and is applicable to all vector spaces and modules, not just free modules. A spanning set is a set of vectors that can be used to generate the entire vector space or module through linear combinations. This means that any element in the vector space or module can be written as a linear combination of the vectors in the spanning set.
In the case of modules, the spanning set may not necessarily be a basis, but it still serves the purpose of generating all elements in the module. In the proof of Theorem 3.3, Conrad is simply using the spanning sets of M and N to show that every elementary tensor in M ⊗R N can be written as a linear combination of elementary tensors of the form x_i ⊗ y_j. This is because of the bilinearity of the tensor product operation.
To address your concern about using "more and more elements" in the spanning set, note that the spanning sets used in the proof are not necessarily finite. They can contain infinitely many elements, but only finitely many of them will have non-zero coefficients in the linear combinations. This is why the sum of the coefficients a_i and b_j is finite.
I hope this clarifies the use of spanning sets in the proof of Theorem 3.3. If you still have further questions or need more clarification, I suggest reaching out to Keith Conrad directly for further guidance.
FAQ: Tensor Products - Keith Conrad - Theorem 3.3 - Tensor Products I
What is a tensor product?
A tensor product is a mathematical operation that combines two mathematical objects, usually vectors or matrices, to create a new object. It is denoted by the symbol ⊗ and follows certain rules and properties.
What is the significance of Keith Conrad's Theorem 3.3 in tensor products?
Theorem 3.3 in Keith Conrad's Tensor Products I is an important result that shows the existence and uniqueness of tensor products for a specific type of mathematical structures called modules. It also provides a concrete construction method for tensor products using generators and relations.
How do tensor products relate to linear transformations?
Tensor products have various applications in linear algebra, especially in the study of linear transformations. They can be used to represent the composition of linear transformations and to define new operations on them.
Can tensor products be extended to more than two objects?
Yes, tensor products can be generalized to any number of mathematical objects. In fact, the concept of tensor products is used in various branches of mathematics, such as algebra, geometry, and topology, to study higher-dimensional structures.
What are some real-world applications of tensor products?
Tensor products have many practical applications, such as in physics, where they are used to describe the behavior of physical systems with multiple dimensions. They are also used in engineering and computer science to model and manipulate complex data structures.
