mnb96
- 715
- 5
mnb96 said:
tiny-tim said:Hi mnb96!
(surprisingly, angular momentum is not generally aligned with rotation. )
SW VandeCarr said:That's an interesting statement. Angular momentum is MLT^-1 where velocity is measured in radians per second. This implies rotation. I can see how a particle moving along a curving path (not a circle) has an angular velocity at every point but is not in a rotary path around some point. Is this what you mean?
tiny-tim said:??
I mean that the angular momentum vector of a rigid body is not generally in the same direction as its angular velocity vector.
Tensors in geometric algebra are mathematical objects that represent multilinear relationships between vectors and covectors. They can be thought of as generalizations of scalars, vectors, and matrices.
Tensors in geometric algebra are useful for representing geometric transformations and physical quantities, such as stress and strain in materials. They also allow for the manipulation of complex geometric relationships in a concise and elegant manner.
In geometric algebra, tensors are represented using a combination of vectors, covectors, and basis elements. This allows for a more intuitive understanding of their properties and makes calculations easier.
Some common operations performed on tensors in geometric algebra include contraction, outer product, and inner product. These operations allow for the manipulation and combination of tensors to create new tensors.
Tensors are heavily used in physics and engineering for their ability to represent complex geometric relationships and physical quantities. They are particularly useful in fields such as electromagnetism, relativity, and mechanics.
