Terminal Velocity and Resistive Forces problem
In summary, the sky diver of mass 81.5 kg reaches a terminal speed of 50.0 m/s when jumping from a slow-moving aircraft. To calculate the acceleration at a speed of 30.0 m/s, the equation mg = bv is used, where b is the friction constant and v is the terminal velocity. However, this may not be entirely accurate as the drag force is often a quadratic function of velocity for large objects moving at high speeds. Possible reasons for an incorrect answer include issues with significant figures and the assumption of a linear drag force.
cheese825
A sky diver of mass 81.5 kg jumps from a slow-moving aircraft and reaches a terminal speed of 50.0 m/s.
(a) What is the acceleration of the sky diver when her speed is 30.0 m/s?
mg = bv
b = (81.5)(9.8) / 50
b = 15.97
(81.5)(9.8) - (15.97)(30) = remaining force, or 319.6 Newtons
319.6 N / 81.5 = 3.921
but it seems, 3.921 is not correct. I must be missing something big.
Any help would be appreciated.
A number of things could cause your answer to be off.
Firstly, if you are entering your answers online be careful with your significant figures - online marking software can be very pedantic about such things.
Secondly, were you explicitly told that the drag force was a linear function of velocity because for large objects moving faster than a few m/s the drag force is usually a quadratic function of velocity.
Your attempt at a solution is on the right track, but there are a few errors in your calculations. Let's break down the problem and go through it step by step.
First, we are given the mass of the sky diver (81.5 kg) and the terminal speed (50.0 m/s). We can use this information to calculate the friction force (F) acting on the sky diver at terminal velocity using the equation F = bv, where b is the friction constant.
F = bv
F = (81.5 kg)(9.8 m/s^2)
F = 798.7 N
Next, we are asked to find the acceleration of the sky diver when her speed is 30.0 m/s. This means that the friction force is no longer equal to the force of gravity (mg), since the sky diver is not at terminal velocity. We can use the equation F = ma to find the acceleration (a).
F = ma
798.7 N = (81.5 kg)a
a = 9.8 m/s^2
So, the acceleration of the sky diver when her speed is 30.0 m/s is 9.8 m/s^2. This is the same as the acceleration due to gravity, which makes sense since the sky diver is no longer experiencing any other forces.
In your attempt at a solution, you calculated the friction constant (b) using the equation mg = bv. This is not correct, as the equation should be mg = bv^2. Additionally, when you used the equation F = ma, you did not include the force of gravity (mg) in your calculation. This is why you got a different answer than the correct acceleration of 9.8 m/s^2.
I hope this helps clarify the problem and your solution. Remember to always double check your equations and units when solving physics problems. Good luck with your studies!
FAQ: Terminal Velocity and Resistive Forces problem
What is terminal velocity?
Terminal velocity is the maximum constant speed that an object reaches when falling through a fluid, such as air or water. It occurs when the drag force of the fluid equals the object's weight, resulting in a net force of zero and no further acceleration.
How is terminal velocity calculated?
Terminal velocity can be calculated using the formula v = √(2mg/ρACd), where v is the terminal velocity, m is the mass of the object, g is the acceleration due to gravity, ρ is the density of the fluid, A is the projected area of the object, and Cd is the drag coefficient.
What factors affect terminal velocity?
The factors that affect terminal velocity include the mass and size of the object, the density and viscosity of the fluid, and the shape and orientation of the object. These factors can also be altered by external forces, such as wind or air temperature.
What is the relationship between terminal velocity and resistive forces?
The resistive forces, also known as drag forces, act in the opposite direction of motion and increase as the speed of the object increases. As an object falls, its speed increases until it reaches terminal velocity, at which point the resistive forces are equal to the object's weight and no further acceleration occurs.
How does surface area affect terminal velocity?
The surface area of an object affects its terminal velocity because it determines the amount of air resistance or drag force acting on the object. Objects with a larger surface area experience greater air resistance and therefore have a lower terminal velocity compared to objects with a smaller surface area.
