The terminal velocity equation as a function of the coefficient γ²hutchphd said:What question do you wish to find out?
Oh, I didn't know. SorryPeterDonis said:@Victor Correa putting content in attachments is not acceptable. You need to post your content directly in the forum, using the PF LaTeX feature for equations. There is a LaTeX Guide link at the bottom left of the edit window when you are composing a post.
You are my hero !vanhees71 said:Obviously in #1 the OP looks for the solution of the equation of motion for free fall including air resistance,
$$\ddot{x}=\dot{v}=g-\gamma v^2.$$
This equation for ##v## can obviously solved by separation of variables,
$$\mathrm{d} t = \frac{\mathrm{d} v}{g-\gamma v^2}.$$
We need the integral
$$\int \mathrm{d} v \frac{1}{g-\gamma v^2} = \frac{1}{g} \int \mathrm{d} v \frac{1}{1-(\sqrt{\gamma/g}v)^2} = \frac{1}{\sqrt{g \gamma}} \text{artanh} \left (\sqrt{\frac{\gamma}{g}} v \right).$$
With the initial condition ##v(0)=0## we thus get
$$t=\frac{1}{\sqrt{g \gamma}} \text{artanh} \left (\sqrt{\frac{\gamma}{g}} v \right).$$
Solved for ##v## you get
$$v(t)=\sqrt{\frac{g}{\gamma}} \tanh (\sqrt{g \gamma} t).$$
The terminal velocity is
$$v_{\infty} = \sqrt{\frac{g}{\gamma}}.$$
So that is easy indeed $$\ddot{x}=\dot{v}=g-\gamma v^2.$$ Just demand$$\dot{v}=g-\gamma v^2=0.$$Victor Correa said:The terminal velocity equation as a function of the coefficient γ²
My problem is thishutchphd said:So that is easy indeed $$\ddot{x}=\dot{v}=g-\gamma v^2.$$ Just demand$$\dot{v}=g-\gamma v^2=0.$$
Yeah, you had a bit of a "can't see the forest through the trees" issue.Victor Correa said:My problem is this
Terminal velocity is the maximum speed that an object can reach when falling through a fluid, such as air. It occurs when the drag force acting on the object is equal to the force of gravity pulling the object down.
Terminal velocity is directly proportional to the drag force acting on an object. This means that as the drag force increases, the terminal velocity also increases.
This equation represents the drag force acting on an object in free fall. The variables 𝑚, 𝛾, and 𝑣 represent the mass, drag coefficient, and velocity of the object, respectively. As the velocity increases, the drag force also increases, until it reaches a point where it is equal to the force of gravity and the object reaches terminal velocity.
Air resistance, also known as drag, is the force that opposes the motion of an object through air. As an object falls through the air, the force of air resistance increases until it is equal to the force of gravity, causing the object to reach terminal velocity. The larger the surface area and the greater the mass of the object, the greater the air resistance and the lower the terminal velocity.
No, terminal velocity can only be reached in a fluid, such as air or water. In a vacuum, there is no air resistance, so an object will continue to accelerate until it reaches the maximum velocity possible.
