Terminal velocity with an initial velocity?
In summary: So in the example given, you can solve for v = v(t). In summary, to find the time it takes for an object to reach terminal velocity with an initial velocity, you can use the formula 1/2pV^2*C*A=ma. However, in reality, an object can only approach terminal velocity asymptotically, meaning it never truly reaches it. The time it takes to reach the ground can be calculated for objects with a large drag to mass ratio, but for objects with a large terminal velocity, the total time will be longer due to the initial slow speed. This can be expressed mathematically using a differential equation.
glueball8
346
As a quick answer, you only approach terminal velocity asymtotically, that is, you could ask when you reach 95% of terminal velocity, but technically when you reach terminal velocity
you mean you can never really reach terminal velocity, everyone keeps telling me that.
But I have a questions that ask when it reaches terminal velocity and how long does it take for the object to fall to the ground.
What's the long answer? lol
That page you cyted is no good. He mixed up free-fall acceleration and drag acceleration.
He got the drag force right though.
Fdrag = .5pCAv^2
Where,
v is velocity (m/s)
C is the object's Drag Coefficient.
A is the object's cross sectional area (),
p and is the density of air (assume 1.25 kg/m3)
Ok. What are the forces acting on the object?
F=ma
Gravity and the drag force. Assume up is the positive direction.
.5pCAv^2 - mg = ma
Here, you have a differential equation. Knowing a = dv/dt
B(v)^2 - D = G dv/dt
Is your differential equation to solve with B, D, and G representing new constants
In the real world, you can think of it as if you're falling at your terminal velocity after nearly reaching it. It's only mathematical rigor that says you can never reach your terminal velocity.
Calculating the time to reach the ground is easy for something with a large drag to mass ratio (skydiver with open parachute). You're quite simply moving at your terminal velocity. It's simply a constant velocity problem in the vertical (y) direction
where V is your terminal velocity and y is the total height to fall.
V = y/t
t = y * V
However, if you have something with a large terminal velocity, the total time will be longer than this because early in the fall, the object was moving slower than it's terminal velocity
Fdrag = .5pCAv^2
Where,
v is velocity (m/s)
F=ma
.5pCAv^2 - mg = ma
Thank you for your reply.
The terminal velocity is 41.4m/s and its only a height of 200m
Hmmm I'm in high school so I'm not really sure differential equation. Did you just take the derivative?
"A simplified real world example of a differential equation is modeling the acceleration of a ball falling through the air (considering only gravity and air resistance). The ball's acceleration towards the ground is the acceleration due to gravity minus the acceleration due to air resistance. Gravity is a constant but air resistance is proportional to the ball's velocity. This means the ball's acceleration is dependent on its velocity. Because acceleration is the derivative of velocity, solving this problem requires a differential equation."
A differential equation is an equation where the derivative of a variable depends on that same variable in one way or another.
For example:
[tex]\frac{dy}{dx} = 2y[/tex]
What you can do in this case is called separation of variables: you bring all the y's to the left and all the x's to the right (or the other way around):
[tex]\frac{dy}{y} = 2\, dx[/tex]
Now, you can integrate both sides:
[tex]\int \frac{dy}{y} = \int 2\, dx[/tex]
[tex] \ln y = 2x + C[/tex]
Then you can solve for y = y(x).
FAQ: Terminal velocity with an initial velocity?
What is terminal velocity with an initial velocity?
Terminal velocity is the maximum velocity that an object will reach when falling through a fluid, such as air or water. The initial velocity refers to the starting velocity of the object before it begins to experience the effects of air resistance.
What factors affect terminal velocity with an initial velocity?
The factors that affect terminal velocity with an initial velocity include the mass and shape of the object, the density and viscosity of the fluid, and the gravitational force acting on the object.
Can terminal velocity be reached with an initial velocity?
Yes, terminal velocity can be reached with an initial velocity. However, the object will need to have a high enough initial velocity to overcome the effects of air resistance and continue to accelerate until it reaches its maximum velocity.
How is the terminal velocity with an initial velocity calculated?
The terminal velocity with an initial velocity can be calculated using the formula Vt = √(2mg/ρACd), where Vt is the terminal velocity, m is the mass of the object, g is the gravitational acceleration, ρ is the density of the fluid, A is the cross-sectional area of the object, and Cd is the drag coefficient.
Why is understanding terminal velocity with an initial velocity important?
Understanding terminal velocity with an initial velocity is important in various fields, such as engineering and physics, as it helps predict the behavior of objects in motion. It is also important for safety, as it can be used to determine safe speeds for objects falling through the air, such as skydivers or parachutes.
