Terminal Velocity's Relationship to Mass
In summary: If I understand correctly, I must also state that \rho, C_{D}, A must also remain constant?Yes, the drag force must remain the same for both objects as well as the mass.
bistan
As shown in the plot above, terminal velocity is shown to increase linearly with the number of coffee filters dropped in a turbulent (air) medium. Therefore, terminal velocity depends on mass. Give an explanation for this starting from Newton's laws.
[tex]\vec{F} = m\vec{a}[/tex]
[tex]\vec{F}_{ab}=-\vec{F}_{ba}[/tex]
Drag force [tex]F_{D}=\frac{1}{2}\rho v^{2}C_{D}A[/tex] where [tex]\rho[/tex] is the mass density of the fluid, [tex]v[/tex] is the velocity of the object relative to the fluid, [tex]A[/tex] is the reference (cross-sectional in our case) area of the object, and [tex]C_{D}[/tex] is the drag coefficient of the object in the fluid.
By Newton's second law: [tex]\sum F=\sum ma=mg-F_{D}=mg-\frac{1}{2}\rho v_{T}^{2}C_{D}A[/tex]
By definition of terminal velocity: [tex]\sum F=0 \Rightarrow 0=mg-\frac{1}{2}\rho v_{T}^{2}C_{D}A[/tex]
This means that the sum of the drag force on the object and the weight of the object must be 0 for the object to have reached terminal velocity. Therefore an object with greater mass has a greater weight, and so the drag force on that object must be equally greater to bring the sum of the forces to 0.
Since the drag force is a function of the square of the terminal velocity on the object, the terminal velocity is greater for an object with greater drag force, and therefore is greater for an object with greater mass.
What does that statement say about the difference between the terminal velocity of a large styrofoam ball v.s. a small metal ball, assuming they have the same mass?
If I understand correctly, I must also state that [tex]\rho, C_{D}, A[/tex] must also remain constant?
FAQ: Terminal Velocity's Relationship to Mass
What is terminal velocity and how does it relate to mass?
Terminal velocity is the maximum speed that an object can reach when falling through a fluid, such as air or water. It is determined by the balance of two forces: the weight of the object and the drag force of the fluid. The greater the mass of an object, the greater the drag force it experiences, thus resulting in a higher terminal velocity.
Does an object's mass affect its terminal velocity?
Yes, an object's mass does affect its terminal velocity. As mentioned before, the greater the mass of an object, the greater the drag force it experiences. This means that a heavier object will reach a higher terminal velocity compared to a lighter object.
Is there a limit to how fast an object can fall due to its mass?
Yes, there is a limit to how fast an object can fall due to its mass. This limit is known as the terminal velocity. Once an object reaches its terminal velocity, it will no longer accelerate and will continue to fall at a constant speed.
How does air resistance play a role in the relationship between mass and terminal velocity?
Air resistance, also known as drag force, is directly related to an object's mass. The greater the mass of an object, the greater the drag force it experiences. This means that air resistance plays a crucial role in determining an object's terminal velocity, as it balances out the weight of the object to reach a constant speed.
Does the shape of an object affect its terminal velocity?
Yes, the shape of an object can affect its terminal velocity. Objects with a streamlined shape, such as a bullet, will experience less drag force compared to objects with a larger surface area, such as a flat sheet of paper. This means that a streamlined object will reach a higher terminal velocity compared to a less aerodynamic object.
