Terminal voltage and current flow
In summary, the problem involves calculating the current and determining the direction of flow in Figure 20.40, using E2 = 19.0 V and r2 = 0.55 Ω. The equation V = Ir can be used to find the current, and for part b, the terminal voltage of each battery needs to be found. However, it is unclear how to proceed with part b as the battery voltages are already given.
narutoish
25
(a) Calculate the magnitude and indicate the direction of flow of current in Figure 20.40. E2 = 19.0 V and r2 = 0.55 Ω.
(b) Find the terminal voltage of each battery.
V = Ir
I found the answer for part a to be 4.52 but i don't know how to get the second one.
V = Ir
I don't understand the question. It looks like you are given the battery voltages...
FAQ: Terminal voltage and current flow
What is terminal voltage?
Terminal voltage refers to the voltage at the terminals of a circuit or device. It is the potential difference between the positive and negative terminals, and is typically measured in volts (V).
How is terminal voltage different from EMF (electromotive force)?
EMF refers to the maximum potential difference that can be generated by a source, while terminal voltage is the actual potential difference that is present at the terminals. This means that terminal voltage may be lower than the EMF due to factors such as internal resistance.
How does current flow in a circuit?
Current flow in a circuit is determined by the voltage and resistance in the circuit, according to Ohm's law (I=V/R). The current flows from the positive terminal to the negative terminal, completing a circuit and powering any devices connected to it.
What is the relationship between terminal voltage and current flow?
The relationship between terminal voltage and current flow is described by Ohm's law, which states that the current flow is directly proportional to the voltage and inversely proportional to the resistance. This means that as the terminal voltage increases, the current flow will also increase if the resistance remains constant.
How does resistance affect terminal voltage and current flow?
Resistance is a key factor in determining the terminal voltage and current flow in a circuit. A higher resistance will result in a lower current flow for a given terminal voltage, while a lower resistance will allow for a higher current flow. Additionally, higher resistance can lead to a decrease in terminal voltage due to voltage drops across components in the circuit.
