RonL
- 219
Tesla Turbine, variation
Just an observation from my shop a couple of weeks ago. Something I have done a few thousand times in my life, and for the first time took notice of what was happening.
Turning the switch of my bench grinder on, the need to use the wire wheel for cleaning a small part, I noticed the large amount of entrained air that was being thrown from the wheel and the thought came to mind of the thread "Tesla Turbine Efficiency" where the question about water in steam doing damage to a disc turbine.
With great care, the hand can feel the actual flow pattern of the air as it is being pulled into the side of the safety cover plate, and then thrown with quit a bit of force from the outer diameter of the wheel, the wire wheel has an open exposeure of about 1/3 of it's diameter.
Danger from flywheel explosion would be reduced, and several wheels on a shaft can be driven by steam or high pressure air. With care in design, all the actions/reactions of a typical Tesla Turbine can be observed.
Just a thought for any of the active turbine builders to think about or test in their shops or labs.
A specific wire wheel designed for the application would be best, but the use of off the shelf items can work.
Don't be shy with questions or comments.
I can always run and hide![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Ron
Ron
