MHB Tessa's questions at Yahoo Answers regarding related rates
  • Thread starter Thread starter MarkFL
    Related rates
Tessa's questions focus on related rates in calculus, specifically involving a person observing a streetlight and the rising water level in a conical tank. For the first problem, the rate at which the angle of elevation of the person's line of sight changes, when 9 feet from the light, is calculated to be 4/15 radians per second. The second question involves determining how fast the water level is rising in a cone-shaped tank when the water is 12 feet deep, with the result being 20/(9π) feet per minute. Both problems utilize differentiation and geometric relationships to derive the rates. The thread provides detailed solutions and formulas for each scenario.
MarkFL
MHB
Here are the questions:
CALC 1 word problems?
Q1.
A person 6 ft tall is watching a streetlight 18 ft high while walking toward it at a speed of 5 ft/sec (see figure 3.53 in the book). At what rate is the angle of elevation of the person's line of sight changing with respect to time when the person is 9 ft from the base of the light?
(Let x(t) denote the distance from the lamp at time t and \theta the angle of elevation at time t)
d(theta)/dt = ? radians/sec
Q2.
Model a water tank by a cone 40 ft high with a circular base of radius 20 feet at the top. Water is flowing into the tank at a constant rate of 80 cubic ft/min . How fast is the water level rising when the water is 12 ft deep?
(Let x(t) denote the radius of the top circle of water at time t and y(t) denote the height of the water at time t.)
dy/dt = ? ft/min
Please help, thank you!
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Tessa,
Q1.) Let's work this problem in general terms so that we then get a formula into which we can plug the given data. Let:
$h$ = the height of the person.
$s$ = the height of the streetlight.
$r$ = the rate at which the person is walking towards the streetlight.
$\theta$ = the angle of inclination of the person's line of sight at time $t$ to the streetlight.
$x$ = the persons horizontal distance at time $t$ from the person to the streetlight.
Now, we may state:
$$\tan(\theta)=\frac{s-h}{x}$$
Differentiating with respect to time $t$, we obtain:
$$\sec^2(\theta)\frac{d\theta}{dt}=\frac{h-s}{x^2}\frac{dx}{dt}$$
Using the Pythagorean identity:
$$\tan^2(u)+1=\sec^2(u)$$
and
$$\frac{dx}{dt}=-r$$
and our original equation, we obtain:
$$\left(\left(\frac{s-h}{x} \right)^2+1 \right)\frac{d\theta}{dt}=\frac{r(s-h)}{x^2}$$
Multiply through by $x^2$:
$$\left((s-h)^2+x^2 \right)\frac{d\theta}{dt}=r(s-h)$$
$$\frac{d\theta}{dt}=\frac{r(s-h)}{(s-h)^2+x^2}$$
Now we may plug in the given data:
$$x=9\text{ ft},\,r=5\frac{\text{ft}}{\text{s}},\,h=6\text{ ft},\,s=18\text{ ft}$$
to get:
$$\bbox[5px,border:2px solid red]{\left.\frac{d\theta}{dt} \right|_{x=9\text{ ft}}=\frac{5(18-6)}{(18-6)^2+9^2}\,\frac{\text{rad}}{\text{s}}=\frac{4}{15}\,\frac{\text{rad}}{\text{s}}}$$
Q2.) Let $R$ be the radius of the tank at the top and $H$ be the height of the tank.
$$V=\frac{1}{3}\pi R^2H$$
Now let $y$ be the depth of water in the tank at time $t$ and $x$ be the radius of the surface at that time. The the volume $V$ of water at time $t$ is given by:
$$V=\frac{1}{3}\pi x^2y$$
By similarity, we know that at any time, we must have:
$$\frac{x}{y}=\frac{R}{H}$$
Hence:
$$x^2=\left(\frac{R}{H}y \right)^2$$
And so we have:
$$V=\frac{1}{3}\pi\left(\frac{R}{H}y \right)^2y=\frac{R^2}{3H^2}\pi y^3$$
Differentiating with respect to $t$, we obtain:
$$\frac{dV}{dt}=\frac{R^2}{H^2}\pi y^2\frac{dy}{dt}$$
And so we have:
$$\frac{dy}{dt}=\frac{dV}{dt}\cdot\frac{H^2}{\pi R^2y^2}$$
Now, plugging in the given data:
$$\frac{dV}{dt}=80\frac{\text{ft}^3}{\text{min}},\,H=40\text{ ft},\,R=20\text{ ft},\,y=12\text{ ft}$$
We have:
$$\bbox[5px,border:2px solid red]{\left.\frac{dy}{dt} \right|_{y=12\text{ ft}}= 80\cdot \frac{40^2}{\pi\cdot20^2\cdot12^2}\, \frac{\text{ft}}{\text{min}}=\frac{20}{9\pi}\, \frac{\text{ft}}{\text{min}}}$$
Hello, Tessa!
MarkFL's explanation is excellent.
I'll solve it directly.
(Q1) A person 6 ft tall is watching a streetlight 18 ft high
while walking toward it at a speed of 5 ft.sec.
line of sight changing when the person is 9 ft from
Code:
    C *
   12 |       *
      |           θ   *
    E * - - - - - - - - - * A
      |         x         |
    6 |                   | 6
    D *-------------------* B
      : - - - - x - - - - :
The person is [math]AB = 6.[/math]
The streetlight is [math]CD = 18.[/math]
His distance is [math]BD = AE = x.\;\;\tfrac{dx}{dt} = \text{-}5[/math] ft/sec.
Let [math]\theta = \angle CAE.[/math]
We have: [math]\:\tan\theta \,=\,\tfrac{12}{x} \quad\Rightarrow\quad x \,=\,12\cot\theta[/math]
Differentate with respect to time:
[math]\;\;\;\tfrac{dx}{dt} \:=\:\text{-}12\csc^2\theta\tfrac{d\theta}{dt} \quad\Rightarrow\quad \tfrac{d\theta}{dt} \:=\:\text{-}\tfrac{1}{12}\sin^2\theta\tfrac{dx}{dt}[/math]
When [math]x = 9,\:\sin\theta \,=\,\tfrac{4}{5}[/math]
We have: [math]\;\tfrac{d\theta}{dt} \:=\:\text{-}\tfrac{1}{12}\left(\tfrac{4}{5}\right)^2(\text{-}5) \:=\:\tfrac{4}{15}[/math]
The angle of elevation is increasing at [math]\tfrac{4}{15}[/math] radians/sec.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
