bremenfallturm
- 47
- 11
Thread moved from the technical forums to the schoolwork forums
TL;DR Summary: I'm trying to figure out why this answer is not correct for a mechanical impact:
"Conservation of energy and conservation of momentum can be used to find the relative velocities after the impact"
Hi! I have a multiple choice test that asks:
What applies to a mechanical impact?
a) The total kinetic energy is always preserved if the coefficient of restitution e>0.
b) The momentum is preserved, except when the impact is ideally plastic (e=0).
c) Both objects stop if the impact is ideally elastic.
d) The coefficient of restitution can be used to determine the relative velocities after the impact.
e) Both objects stop if the impact is ideally plastic.
f) The law of conservation of energy and the law of momentum can be used to determine the relative velocities after the impact.
d) is the correct answer, which does make sense, but I have used f) to solve problems relating to impact before.
I know that we can not use these laws during the impact, but setting them up before the impact and after should work? Is the key here that you have to know the masses of the objects, or what's the matter?
