Test Review 3 - convergence of series
In summary: The root of the equation x2- x- 2= 0 is 2. Thus, by the relation between sn and sn+1, we can show that sn<root(sn+2).
cmurphy
30
Problem: Suppose 0 < sn < 2 and sn+1 = root (sn + 2) for n in N. Prove
0 < sn < sn+1 < 2 holds for all n in N. Does sn converge? If so, what is the limit.
I am able to show that sn+1 < 2 by squaring the equation sn+1 = root (sn + 2) and making a substitution.
How would I go about showing that sn < sn+1?
Also, if sn < sn+1 < 2 for all n, then the series sn must converge (because it is bounded). In order to find the limit, could I take the limit of both sides of the equation (sn+1)^2 = sn + 2?
i.e. lim (sn+1)^2 = lim (sn+2)).
Let s = lim sn = lim sn+1
Then s^2 = s + 2
s^2 - s - 2 = 0
But then s = 2 and s = -1, which would indicate that there is no limit.
So which is it - is there a limit or not? (I thought that if a sequence is bounded, it must have a limit. Is that correct?)
Does the problem really say 0< sn< 2? If so that makes proving that 0< sn+1< 2 trivial! Are you sure it doesn't say 0< s1< 2?
Prove
What substitution, exactly? (And don't forget the 0< sn part!)
Hint: what are the roots of the equation x2- x- 2= 0?
and is an increasing sequence!
Then s^2 = s + 2
s^2 - s - 2 = 0
An increasing sequence with an upper bound must have a limit. That's part of the "monotone convergence" property.
Can you explain why "s= 2 and s= -1" would "indicate that there is no limit"?
(Notice that [itex]x_n= \frac{n-1}{n}[/itex] has the property xn< 1 for all n. What is its limit?)
Yes, the problem does say that 0 < sn <2, and that sn+1 = root(sn +2).
Thus I said that (sn+1)^2 = sn + 2.
Then sn = (sn+1)^2 - 2
Thus 0 < sn = (sn+1)^2 - 2 < 2
And 2 < (sn+1)^2 < 4
So root 2 < sn+1 < 2.
Thus I have that sn+1 < 2.
I obviously have that 0 < sn, from the given statement. I cannot figure out how to show that sn < sn+1 to complete this part of the proof.
I did figure out that since the roots (limits) of the equation s^2 = s + 2 are 2 and -1, that the limit cannot be -1 since all sn > 0. Thus the limit is 2.
And, since the sequence is shown to be monotone and bounded, we know that it does need to converge.
So the only part left is showing that sn < sn+1. Please help!
To show sn<sn+1 use the relation between sn and sn+1.
That is, showing sn<sn+1 is the same as showing sn<root(sn+2).
FAQ: Test Review 3 - convergence of series
1. What is the definition of convergence of a series?
The convergence of a series refers to the behavior of the sequence of partial sums as the number of terms increases. A series is said to converge if the sequence of partial sums approaches a finite limit as the number of terms increases towards infinity.
2. How can I determine if a series converges or diverges?
There are several tests that can be used to determine the convergence or divergence of a series, such as the comparison test, ratio test, and integral test. These tests involve comparing the given series to a known convergent or divergent series, or evaluating the limit of certain functions.
3. Can a series converge to a value other than its limit?
No, a series can only converge to its limit. If a series converges to a value other than its limit, then it is said to diverge.
4. What is the difference between absolute and conditional convergence?
Absolute convergence refers to a series that converges regardless of the order in which the terms are added. On the other hand, conditional convergence refers to a series that only converges when the terms are added in a specific order. An example of a conditionally convergent series is the alternating harmonic series.
5. Can a divergent series have a sum?
No, a divergent series does not have a sum. The sum of a series only exists if the series converges to a finite limit. If the series diverges, it means that the terms are increasing towards infinity and there is no finite value that the series approaches.
