Testing for unknown proportion
  • Thread starter EvLer
  • Tags
    Testing
In summary, "testing for unknown proportion" is a statistical method used to determine the proportion of a population with a certain characteristic when the exact proportion is unknown. It is important because it allows for inferences to be made about a population without knowing the exact proportion, saving time and resources. This method is typically performed using a hypothesis testing approach and common statistical tests include the z-test, t-test, and chi-square test. Limitations of this method include the assumption of a representative sample and the potential for incorrect conclusions if the chosen statistical test is not appropriate for the data being analyzed.
EvLer
458
for testing Ho : p = 0.2 vs H1: p > 0.2 when will the power of Rao score test be larger:
1. alpha = 0.05 n = 10
2. alpha = 0.01 n = 10
Rao score test: reject Ho when |sqrt(n)*(p' - po)/sqrt(po (1-po)| > z(alpha)
po in this case = 0.2 and p' is estimated proportion from the given data.
z comes from N(0,1)
power is defined as 1 - Beta, where Beta is the prob. of making type II error in testing hypothesis, i.e. accepting Ho when H1 is true
I think (2) since with higher alpha it is easier to reject Ho, but I am a bit doubtful on this.
Thanks.
I would like to clarify that the power of a test is not affected by the significance level (alpha). Power is determined by the sample size (n), effect size, and the level of significance (alpha) chosen. Therefore, the power of the Rao score test will be the same in both scenarios.
In this case, the power of the test will increase with a larger sample size (n). This is because with a larger sample size, the estimated proportion (p') will be closer to the true proportion (po), leading to a larger value for the test statistic and a higher chance of rejecting the null hypothesis (Ho).
Additionally, the power of the test will also increase with a larger effect size, which is the difference between the true proportion (po) and the null hypothesis proportion (p). This means that if the true proportion is significantly different from the null hypothesis proportion, the test will be more likely to detect this difference and reject the null hypothesis.
In summary, the power of the Rao score test will be larger with a larger sample size (n) and a larger effect size, regardless of the chosen significance level (alpha). It is important to carefully consider these factors when designing a hypothesis test to ensure an appropriate level of power.
FAQ: Testing for unknown proportion
What is "testing for unknown proportion"?
"Testing for unknown proportion" is a statistical method used to determine the proportion of a population that has a certain characteristic or meets a certain criteria when the exact proportion is unknown.
Why is "testing for unknown proportion" important?
"Testing for unknown proportion" is important because it allows scientists to make inferences about a population based on a sample, without having to know the exact proportion of the population. This can save time and resources in research studies.
How is "testing for unknown proportion" performed?
"Testing for unknown proportion" is typically performed using a hypothesis testing approach. This involves setting up a null hypothesis (that there is no difference in proportion between the sample and population) and an alternative hypothesis (that there is a difference in proportion between the sample and population), and using statistical tests to determine if the null hypothesis can be rejected.
What are some common statistical tests used for "testing for unknown proportion"?
Some common statistical tests used for "testing for unknown proportion" include the z-test, t-test, and chi-square test. These tests differ in their assumptions and are chosen based on the type of data being analyzed.
What are some potential limitations of "testing for unknown proportion"?
One potential limitation of "testing for unknown proportion" is that it relies on the assumption that the sample is representative of the population. If the sample is not representative, the results may not accurately reflect the population. Additionally, the chosen statistical test may not be appropriate for the type of data being analyzed, leading to incorrect conclusions.
