Testing if the momentum operator is Hermitian
In summary, the conversation is about a student seeking help with understanding complex conjugates of functions and testing operators for Hermitian properties. Through the use of integration by parts and normalization conditions, the student is able to show that the momentum operator satisfies the Hermitian condition. However, it is important to note that the proof depends on the choice of Hilbert space and the properties of the operator must be checked before assuming it is Hermitian.
kkan2243
Hi. I'm not too good at maths and I'm having some trouble figuring out the basics of what to do with complex conjugates of functions.
Our lecturer has set a couple problems requiring us to test if a few operators are Hermitian. Before I can get to those I thought I'd test the basic momentum operator: [tex](\frac{\hbar}{i} \frac{\partial}{\partial x})[/tex].
Using integration by parts:
[tex]\int_{-\infty}^\infty \Psi^\ast(x,t) (\frac{\hbar}{i} \frac{\partial}{\partial x}) \Psi(x,t) dx = \frac{\hbar}{i} [\Psi^\ast(x,t)\Psi(x,t)]^\infty_{-\infty} - \int_{-\infty}^\infty \Psi(x,t) (\frac{\hbar}{i} \frac{\partial}{\partial x}) \Psi^\ast(x,t) dx [/tex]
Now how do I deal with the first term? Does it reduce to 0 somehow? I recongnise that the second term should be equal to the LHS for the momentum operator to be shown as Hermitian.
Cheers. Kaan
EDIT: sorry, I found the answer https://www.physicsforums.com/showthread.php?t=138552"
[itex]\Psi[/itex] must be normalizable, therefore [itex]\Psi^* \Psi[/itex] must go to zero as x goes to infinity in either direction.
Yes first term on RHS goes to zero because of the normalization condition on the wavefunction [tex]\Psi(x,t) ->0 [/tex] as [tex] x-> \infty [/tex] ( or [tex] -\infty [/tex] ).
So you're left with:
[tex]\int_{-\infty}^\infty \Psi^\ast(x,t) (\frac{\hbar}{i} \frac{\partial}{\partial x}) \Psi(x,t) dx = \int_{-\infty}^\infty \Psi(x,t) (-\frac{\hbar}{i} \frac{\partial}{\partial x}) \Psi^\ast(x,t) dx [/tex]
Thus the Hermitian condition, [tex]\int_{-\infty}^\infty \Psi^\ast(x,t) \hat{P} \Psi(x,t) dx = \int_{-\infty}^\infty \Psi(x,t) \hat{P^\ast} \Psi^\ast(x,t) dx [/tex]
is satisified since the conjugate of the momentum operator is just minus the momentum operator.
Is this a valid proof?
Given an arbitrary ket [tex]|a\rangle[/tex]:
[tex]\langle a|\hat{\textbf{p}}a\rangle[/tex]
[tex]=\langle \hat{\textbf{p}}^{\dagger}a|a\rangle[/tex]
If [itex]\hat{\textbf{p}}[/itex] is Hermitian, then
[tex]\hat{\textbf{p}}^{\dagger}=\hat{\textbf{p}}[/tex]
So
[tex]\langle \hat{\textbf{p}}^{\dagger}a|a\rangle = \langle \hat{\textbf{p}}a|a\rangle[/tex]
[tex]=\left(\langle a|\hat{\textbf{p}}a\rangle\right)^{*}[/tex]
You can't assume P is hermitean, you have to prove such thing ! You can't prove it in the abstract Dirac language. You must choose a Hilbert space. Define the operators and only then check for properties such as continuity/boundedness, hermiticity, unitarity, etc.
FAQ: Testing if the momentum operator is Hermitian
What is the momentum operator?
The momentum operator is a mathematical operator used in quantum mechanics to describe the momentum of a particle. It is represented by the symbol p and is defined as the derivative of the position operator with respect to time.
Why is it important to test if the momentum operator is Hermitian?
Hermiticity is an important property of operators in quantum mechanics. A Hermitian operator has real eigenvalues, which correspond to physically meaningful observables. It is important to test if the momentum operator is Hermitian to ensure that it accurately describes the momentum of a particle and can be used to make predictions about its behavior.
How is the Hermiticity of the momentum operator determined?
The Hermiticity of an operator is determined by checking if it satisfies the condition of Hermitian conjugation. This means that the operator's adjoint, or complex conjugate transpose, is equal to the operator itself. In the case of the momentum operator, this would involve checking if p† = p.
What are the consequences if the momentum operator is not Hermitian?
If the momentum operator is not Hermitian, it means that it does not accurately describe the momentum of a particle. This can lead to incorrect predictions about the behavior of the particle and can cause inconsistencies in calculations and theoretical models.
How can we experimentally test the Hermiticity of the momentum operator?
Experimental tests of the Hermiticity of the momentum operator can be done by measuring the momentum of a particle and comparing it to the predictions made using the operator. If the results are consistent, it provides evidence that the momentum operator is indeed Hermitian. Additionally, experiments can be designed to specifically test the condition of Hermitian conjugation for the momentum operator.
