MHB Thank you! I'm glad it was helpful.
  • Thread starter Thread starter Albert1
    Integers
The discussion centers on proving that each term of the sequence defined by a_n = 160{n+6 choose 6} is an integer for n ≥ 3. The proof uses mathematical induction, starting with the base case where a_3 is calculated and shown to be an integer. The inductive step demonstrates that if the formula holds for n, it also holds for n+1, reinforcing the integer property. Corrections to the original formula were acknowledged, confirming the validity of the approach. The conclusion emphasizes that the result follows from the properties of binomial coefficients, which are inherently integers.
Albert1
$a_1=3,a_2=5757,\,\, a_n=\dfrac {7(a_a+a_2+-------+a_n)}{n}, \,\, (n\geq2)\,\, prove \,\,each\,\, term\,\, of\,\, a_n\,\,
is \,\, an \,\, integer$
correction :
$a_1=3,a_2=5757,\,\, a_n=\dfrac {7(a_1+a_2+-------+a_{n-1})}{n}, \,\, (n\geq2)\,\, prove \,\,each\,\, term\,\, of\,\, a_n\,\,
Mathematics news on Phys.org
Albert said:
$a_1=3,a_2=5757,\,\, a_n=\dfrac {7(a_{\color{red}1}+a_2+-------+a_{n{\color{red}-1}})}{n}, \,\, (n\geq2)\,\, prove \,\,each\,\, term\,\, of\,\, a_n\,\,
[sp]Assuming that I'm right in making those corrections to the question, I claim that $$a_n = 160{n+6\choose6}$$ for all $n\geqslant3$. The result then follows because binomial coefficients are integers.
To prove the claimed result by induction, check first that $a_1+a_2 = 3+5757 = 5760 = 2^7\cdot3^2\cdot5$, so that $a_3 = \dfrac{2^7\cdot3^2\cdot5\cdot7}3 = 2^7\cdot3\cdot5\cdot7.$ But $$160{9\choose6} = 2^5\cdot5\cdot\frac{9\cdot8\cdot7}{1\cdot2\cdot3} = 2^7\cdot3\cdot5\cdot7.$$ That establishes the base case $n=3$.
Now suppose that the result is true for $n$. Since $a_n = \frac7n(a_1+a_2 + \ldots + a_{n-1})$, it follows that $$a_1+a_2 + \ldots + a_{n-1} = \frac{na_n}7 = \frac{160n}7{n+6\choose6},$$ and so $$a_1+a_2 + \ldots + a_n = \frac{160n}7{n+6\choose6} + 160{n+6\choose6} = \frac{160(n+7)}7{n+6\choose6}.$$ Therefore $$a_{n+1} = \frac7{n+1}(a_1+a_2 + \ldots + a_n) = \frac{160(n+7)}{n+1}{n+6\choose6} = \frac{160(n+7)\cdot (n+6)!}{(n+1)\cdot6!\cdot n!} = \frac{160(n+7)!}{6!(n+1)!} = 160{n+7\choose n+1} = 160{n+7\choose 6}.$$ That completes the inductive step.[/sp]
sorry a typo
Yes you are right in making those corrections to the question
very good solution !
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
