- #36
Gnosis
- 147
- 4
LionTigerFire said:Ok my friend and I are having a disagreement about gearing on a GoPed. I am stating that if you change the tire size of a California GoPed the speed of the GoPed will not change. This is all theory so am not taking into account friction, mass or the like.
For those of you who do not how a GoPed works the tire is NOT driven by the axel as it is on a car or by sprocket like a motorcycle, but is driven by a spindle rotating directly against the rubber of the tire.
I understand that if you double the the size of tire of a car(in theory) the car will go twice as fast. My grounds for this outcome not applying to a GoPed is that if you double the size of the tire will rotate half as fast.
If somepeople could prove to me right or wrong that would be awesome
When employing the use of a drive-spindle to directly drive the circumference of a tire, changes made to the tire’s diameter do NOT alter the vehicle’s speed per a given drive-spindle RPM (assuming no slippage of the drive spindle). So, you stand correct.
For instance:
While the ratio between spindle RPM and tire RPM most definitely changes when doubling the tire's diameter, this ratio is essentially irrelevant. A tire whose circumference has been doubled will by ratio, appear to spin at just half of its previous RPM HOWEVER, it must be remembered that per the tire’s doubled circumference, it now only needs to rotate at half the RPM to yield the identical previous vehicle speed.
Let’s assume the drive-spindle has a 6” circumference therefore, per each of its revolutions it will move the tire’s circumference 6” as well. Regardless of what change is made to the tire’s diameter, it still only moves 6” of the tire’s circumference per drive-spindle revolution therefore the vehicle itself has only moved 6” per drive-spindle revolution. So, in this type of drive mechanism (drive-spindle directly driving tire’s circumference), only changes made to the circumference of the drive-spindle and/or the drive-spindle’s RPM can alter the speed of the vehicle. Again, changes made to the tire’s diameter (therefore, its circumference) are irrelevant.
