The acceleration of a descending airplane
In summary, the conversation is about determining the acceleration of an airplane descending in a circular pattern with a constant radius of 250 meters. The airplane has a horizontal speed of 75 m/s and a downward speed of 5 m/s, which is increasing at a rate of 2 m/s2. The formula for finding acceleration in circular motion is discussed, as well as the inclusion of the downward acceleration in the equation. It is suggested to derive the equation from first principles and to consider the position of the aircraft as a function of time. The final equation for finding the magnitude of acceleration is explained as taking the square root of the sum of the squares of the horizontal and vertical components.
deveny7
An airplane descends in a circular pattern with a constant radius of 250 meters. The airplane has a horizontal speed of 75 m/s (constant) and a downward
Determine the acceleration of the airplane.
an = v2 / ρ
a = √(at2 + an2)
Finding the acceleration for a circular motion is easy, but I am having trouble including the downward acceleration. Any help is greatly appreciated!
If all else fails, derive it from first principles.
Assuming that the aircraft is at height h and is circling the origin, can you write down its position as a function of time? If so, what's its acceleration?
What equation could I use to include the height and downward speed as a function of time?
You figured out the centripetal accleration, and the problem states the downwards acceleration is 2 m / s2, which would be the components of the acceleration vector (horizontal and vertical). To get the magnitude, take the square root of the sum of the squares of the components.
The acceleration of the airplane is a combination of its horizontal acceleration and its vertical acceleration. The horizontal acceleration remains constant at 75 m/s, while the vertical acceleration is increasing at a rate of 2 m/s2. Therefore, the total acceleration can be calculated using the Pythagorean theorem: a = √(at2 + an2), where at is the horizontal acceleration and an is the vertical acceleration.
Substituting the given values, we get:
a = √((75 m/s)2 + (5 m/s + 2 m/s2t)2)
= √(5625 m2/s2 + (5 m/s + 2 m/s2t)2)
= √(5625 m2/s2 + 25 m2/s2 + 20 m/s2t + 4 m2/s4t2)
= √(5650 m2/s2 + 20 m/s2t + 4 m2/s4t2)
= √(5650 m2/s2 + 20 m/s2(0) + 4 m2/s4(0)2) [since the airplane is already at a constant horizontal speed and is not changing in time]
= √(5650 m2/s2)
= 75.166 m/s2
Therefore, the acceleration of the airplane is approximately 75.166 m/s2. This can also be represented as 75.166 m/s2 in the direction of the resultant velocity vector, which is at an angle of 90 degrees with respect to the horizontal velocity vector.
Related to The acceleration of a descending airplane
1. What is the acceleration of a descending airplane?
The acceleration of a descending airplane is the rate at which the airplane's velocity changes as it descends towards the ground. It is typically measured in meters per second squared (m/s^2).
2. How does the acceleration of a descending airplane affect passengers?
The acceleration of a descending airplane can cause passengers to feel a sensation of being pushed back into their seats. This is due to the increase in acceleration as the airplane gets closer to the ground.
3. Does the acceleration of a descending airplane change during different phases of flight?
Yes, the acceleration of a descending airplane can change during different phases of flight. For example, during takeoff and landing, the acceleration is typically higher compared to cruise flight.
4. What factors can affect the acceleration of a descending airplane?
Several factors can affect the acceleration of a descending airplane, including the weight and size of the airplane, air density, wind speed and direction, and the angle of descent.
5. How is the acceleration of a descending airplane calculated?
The acceleration of a descending airplane can be calculated using the formula a = (v^2 - u^2)/2d, where a is acceleration, v is the final velocity, u is the initial velocity, and d is the distance traveled during descent.
