The acceleration of protons using a changing magnetic field
In summary: Yes, the speed changes because of the electric field,but##\vec a=\frac{d\vec v}{dt}## is a nonzero vectorwhen the magnitude of ##\vec v## changes, or the direction of ##\vec v## changes, or both.
Jaccobtw
163
32
In earlier learning sequences we described how a static magnetic field cannot change the speed (and therefore kinetic energy) of a free charged particle. A changing magnetic field can, and this is one way particle beams are accelerated. Consider free protons following a circular path in a uniform magnetic field with a radius of 1m. At t=0s, the magnitude of the uniform magnetic field begins to increase at 0.001T/s. Enter the tangential acceleration of the protons in m/s^2: positive if they speed up and negative if they slow down.
$$F = qvBsin\theta$$
$$ r = \frac{mv}{qB}$$
$$\Phi = \int B \cdot dA$$
If we increase the magnetic field, the radius of the particle's circular path will decrease which increases the tangential acceleration. How do I find the tangential acceleration. Do I use derivatives?
Note that since ##\vec F_{mag} = q\vec v \times \vec B##, we necessarily have ##\vec F_{mag} \perp \vec v##. So, ##\vec F_{mag}## can't change the magnitude of ##\vec v##.
Are there other relevant equations needed?
A labeled diagram would help.
Likes Jaccobtw and Delta2
A time varying magnetic field generates an electric field which will give the tangential acceleration to the protons. Use Faraday's law to calculate the magnitude of the generated electric field at r=1m.
The field lines of this electric field are concentric circles, centered at the origin, with their plane perpendicular to the uniform magnetic field.
Likes Jaccobtw
Thanks for the big hint!. The protons are accelerated by the electric field.
My hint was a little more subtle.
Note that, when the magnetic force is the only force,
the protons are accelerated by the magnetic field
since their velocity vectors are turned by the magnetic force.
But doesn't the increasing tangential velocity only come from the electric field? The magnetic force is perpendicular to the proton's motion so it's speed can't increase from that, only direction can change.
but
This might be helpful:
Likes nasu and Jaccobtw
FAQ: The acceleration of protons using a changing magnetic field
What is the purpose of accelerating protons using a changing magnetic field?
The purpose of accelerating protons using a changing magnetic field is to increase their energy and speed, allowing them to be used in various applications such as particle accelerators, medical treatments, and nuclear reactions.
How does a changing magnetic field accelerate protons?
A changing magnetic field creates a force on charged particles, such as protons, causing them to accelerate. This is known as the Lorentz force, where the force is proportional to the charge of the particle, the strength of the magnetic field, and the velocity of the particle.
What are the advantages of using a changing magnetic field for proton acceleration?
Using a changing magnetic field for proton acceleration allows for precise control and manipulation of the particles, as well as the ability to accelerate them to high energies. It also avoids the need for large and expensive equipment, such as radiofrequency cavities, which are used in other methods of particle acceleration.
Are there any limitations to using a changing magnetic field for proton acceleration?
One limitation is that the acceleration is limited by the strength of the magnetic field. Additionally, the particles may experience synchrotron radiation, which can cause energy loss and limit the maximum achievable energy.
How is the changing magnetic field created for proton acceleration?
The changing magnetic field can be created using various methods, such as using an alternating current through a coil or rotating permanent magnets. In some cases, the magnetic field can also be created by the movement of the particles themselves, such as in a synchrotron.
