The angle @ which the particle hits the wall
In summary, the conversation is about someone seeking help with calculating the incident angle of a spherical ball hitting a curvilinear wall. They mention that it is easy to calculate when the plane is aligned with either the x or y-axis, but they need help with the curvilinear case. Another person suggests copying the angle it hits the wall and adding the curvilinear to the other side, but the person seeking help asks for more clarification and an example case. They also make a correction to the velocity components.
ranaroy
dear all,
i am working on a problem, but not having found the solution yet.
i have a wall section (in a 2D x-y plane) on which spherical balls hit and get reflected.
i know the x-velocity and y-velocity of the particle when it hits the wall.
i need to calculate the impact (incident) angle of the ball on the wall.
it is easy to calculate when the plane is either along x-axis or y-axis. but, my plane is curvilnear (i know the radius of curvature). can i calculate the incident angle for this curvilinear plane ?
pls help. thank you.
I don't know this very well, but here's a shot. Take the angle it hits the and copy that same angle it hits on the wall and add the curvilinear to the other side.
dear asaplease,
thank you for your try.
can u explain it once more in detail. i didnt understand well.
you mean to say, first i will do theta = atan(V_y/V_x) and calculate the angle.
then, what shoud i do ?
to make it more clear for me, can u do one example case.
say V_y = 3 m/s , V_y = 4 m/s
So, theta = 37 degree.
pls help
sorry, the above velocity components should read
V_y = 3 m/s , V_x = 4 m/s
sorry for the mistake.
FAQ: The angle @ which the particle hits the wall
What is the angle at which the particle hits the wall?
The angle at which a particle hits a wall is the angle formed between the vertical line of the wall and the direction of the particle's motion.
Does the angle at which the particle hits the wall affect its trajectory?
Yes, the angle at which a particle hits a wall can greatly affect its trajectory. If the particle hits the wall at a perpendicular angle, it will bounce straight back. However, if it hits the wall at an angle, it will bounce off at a different angle due to the law of reflection.
How does the speed of the particle affect the angle at which it hits the wall?
The speed of the particle does not directly affect the angle at which it hits the wall. However, it can affect the angle at which it bounces off the wall due to the law of reflection. A faster particle will have a greater momentum and may bounce off the wall at a different angle compared to a slower particle.
Can the angle at which a particle hits the wall be calculated?
Yes, the angle at which a particle hits a wall can be calculated using trigonometric functions and the initial velocity of the particle. The angle can also be estimated by observing the trajectory of the particle before and after it hits the wall.
How does the surface of the wall affect the angle at which the particle hits it?
The surface of the wall can affect the angle at which a particle hits it in two ways. First, a smooth surface will result in a predictable reflection angle, while a rough or uneven surface may cause the particle to bounce off at a different angle. Second, the material and texture of the wall can affect the friction and force of impact, which may also alter the angle at which the particle hits the wall.
9K
