I The answer is 15! What is the problem?
  • I
  • Thread starter Thread starter Astronuc
The "packing coloring" problem explores how to fill an infinite grid with numbers while ensuring identical numbers maintain a specified distance apart, measured by taxicab distance. A recent computer-assisted proof has established that the minimum number of numbers required to solve this problem is 15, a significant finding that refines previous estimates. Initially, researchers, including Wayne Goddard, demonstrated that 22 numbers could solve the problem, while five was insufficient, indicating the true solution lies between these two figures. The discussion also touches on the reliability of algorithms in mathematical proofs, highlighting skepticism about their accuracy. This exploration underscores the complexity and intrigue of combinatorial mathematics.
Astronuc
Staff Emeritus
The Number 15 Describes the Secret Limit of an Infinite Grid​
https://www.quantamagazine.org/the-...he-secret-limit-of-an-infinite-grid-20230420/
The “packing coloring” problem asks how many numbers are needed to fill an infinite grid so that identical numbers never get too close to one another. A new computer-assisted proof finds a surprisingly straightforward answer.
In 2002, Wayne Goddard of Clemson University and some like-minded mathematicians were spitballing problems in combinatorics, trying to come up with new twists on the field’s mainstay questions about coloring maps given certain constraints.
Eventually they landed on a problem that starts with a grid, like a sheet of graph paper that goes on forever. The goal is to fill it with numbers. There’s just one constraint: The distance between each occurrence of the same number must be greater than the number itself. (Distance is measured by adding together the vertical and horizontal separation, a metric known as “taxicab” distance for the way it resembles moving on gridded urban streets.) A pair of 1s cannot occupy adjoining cells, which have a taxicab distance of 1, but they can be placed in directly diagonal cells, which have a distance of 2.
Initially, Goddard and his collaborators wanted to know whether it was even possible to fill an infinite grid with a finite set of numbers. But by the time he and his four collaborators published this “packing coloring” problem in the journal Ars Combinatoria in 2008, they had proved that it can be solved using 22 numbers. They also knew that there was no way it could be solved with only five numbers. That meant the actual answer to the problem — the minimum number of numbers needed — lay somewhere in between.
Mathematics news on Phys.org
Poor dude who has to prove the correctness of those programs or calculations. I remember I, too, once used an algorithm to cover a finite number of exceptions, the exceptional simple Lie algebras, and months later I found a loophole. I checked manually all the cases the algorithm missed, so my general result remained true. But I do not trust such algorithms very much anymore. On the other hand, who really read and understood Wiles's proof?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
13K
25K
