The arm of a crane at a construction site is 15.0 m long
In summary, the maximum torque that the crane can withstand is 192 N · m, calculated by using the equation torque = rFsin θ with a radius of 15 m, a force of 779 N, and an angle of 15.8 degrees.
DrunkApple
111
15.0 m long, and it makes an angle of 15.8
with the horizontal. Assume that the max-
imum load the crane can handle is limited
by the amount of torque the load produces
around the base of the arm.
What maximum torque can the crane with-
stand if the maximum load the crane can
handle is 779 N?
Answer in units of N · m
torque = rFsin θ
torque = radius * Force of gravity * sin θ
= 15 m * 779 N * sin 15.8
I don't get what is wrong...
"torque = 15 m * 779 N * sin 15.8"
Surely it should be cosine rather than sine?
uhhh can i ask why it's cosine?
Torque is the vertical force times the horizontal distance from the pivot. The angle of the crane with horizontal is given. So 15*cos(15.8) is the horizontal component of the crane's length.
Your attempt at a solution is incorrect. The formula for torque is τ = rFsinθ, where r is the radius of the arm, F is the force applied, and θ is the angle between the arm and the force. In this case, the force is not the force of gravity, but rather the maximum load the crane can handle. So the correct formula would be τ = 15 m * 779 N * sin 15.8, which equals approximately 1,947 N · m. This is the maximum torque the crane can withstand with a maximum load of 779 N.
Related to The arm of a crane at a construction site is 15.0 m long
1. What is the purpose of the arm of a crane at a construction site?
The arm of a crane at a construction site is used to lift and move heavy materials and equipment to different locations on the site.
2. How long is the arm of a crane at a construction site?
The arm of a crane at a construction site is 15.0 meters long.
3. How much weight can the arm of a crane at a construction site hold?
The weight capacity of the arm of a crane at a construction site can vary depending on the specific type and size of the crane, but they are designed to safely lift and move heavy loads, often ranging from several tons to over 100 tons.
4. How does the arm of a crane at a construction site work?
The arm of a crane at a construction site is made up of several segments, or sections, that can be extended or retracted to reach different heights. The arm is attached to a rotating base, allowing it to move in a circular motion, and a pulley system is used to lift and lower the load.
5. Are there any safety precautions that need to be taken when operating the arm of a crane at a construction site?
Yes, there are several safety precautions that need to be followed when operating the arm of a crane at a construction site. This includes proper training and certification for the crane operator, regular inspections and maintenance of the crane, and following all safety protocols and guidelines while operating the crane to avoid accidents or injuries.
12K
