The Asymtotic Eiegen Values of a Circulant matrix
  • Thread starter EngWiPy
  • Tags
    Matrix
In summary, the question posed is whether it is legal to do analysis in an asymptotic sense for the eigenvalues of a circulant matrix, in which case they would all be equal. The answer is no, as this would imply the matrix is the identity matrix or a sequence of Gaussian random variables, which is not true for all circulant matrices. A counter-example is a matrix of all 1's, which would have only one non-zero eigenvalue regardless of its size.
EngWiPy
1,368
61
Hi,
The eigenvalues of a circulant matrix are given by:
[tex]\lambda_n=\sum_{l=0}^Lh_l\exp\left(-j\frac{2\pi}{N}nl\right)[/tex]
for n=0,1,...N-1. Is it legal to do analysis in asymptiptic sense (as N approaches infinity), in which case:
[tex]\lambda_1=\cdots=\lambda_N=\sum_{l=0}^Lh_l[/tex]??
Thanks
Mathematics news on Phys.org
I'm not a mathematician so my answer will lack rigor, but here goes:
I would think the answer is no. The eigenvalues are the Fourier transform or spectrum of the top row (or first column) of the circulant matrix. For the eigenvalues to all be equal defines a constant spectrum, which implies that the first row consists of a one followed by all zeros. Note that this matrix is the identity matrix. If the eigenvalues are instead allowed to vary randomly by a little bit, then the spectrum looks approximately "white" such as you see for Gaussian noise. The row vector is thus a sequence drawn from a Gaussian random variable. Both of these are very special cases, of course, and there is no reason to believe that an arbitrary circulant matrix will resemble them. Hence I believe that your proposition is untrue in general.
EDIT: Just thought of an obvious counter-example: a matrix of all 1's. No matter how large it gets, it has one non-zero eigenvalue and all rest zeros.
Related to The Asymtotic Eiegen Values of a Circulant matrix
1. What is a circulant matrix?
A circulant matrix is a special type of square matrix in which each row is obtained by cyclically permuting the elements of the previous row. This means that the first row is repeated as the last row, and the remaining rows are created by shifting the elements of the first row to the right.
2. What are the asymptotic eigenvalues of a circulant matrix?
The asymptotic eigenvalues of a circulant matrix are the eigenvalues that approach a constant value as the matrix size increases. In other words, as the matrix becomes larger and larger, these eigenvalues will not change significantly and will stabilize at a certain value.
3. How do you calculate the asymptotic eigenvalues of a circulant matrix?
The asymptotic eigenvalues of a circulant matrix can be calculated using the discrete Fourier transform (DFT). This involves converting the circulant matrix into a diagonal matrix using the DFT, and then taking the diagonal elements as the asymptotic eigenvalues.
4. What is the significance of the asymptotic eigenvalues of a circulant matrix?
The asymptotic eigenvalues of a circulant matrix can provide insight into the long-term behavior of certain systems or processes. They can also be used to approximate the eigenvalues of large circulant matrices, which can be computationally expensive to calculate.
5. Can a circulant matrix have complex asymptotic eigenvalues?
Yes, a circulant matrix can have complex asymptotic eigenvalues. This is because the DFT involves complex numbers, and these complex numbers can result in complex eigenvalues. However, in many cases, the asymptotic eigenvalues of a circulant matrix will be real numbers.
  • Linear and Abstract Algebra
