The bizarre rotation of galaxies
In summary, Wallsy is asking about the strange rotation of galaxies that he has seen in pictures. He suggests that it may be due to the presence of dark matter, which has magical properties.
Wallsy
The planets rotate around our sun faster and faster the closer they are.The Suns rotate around a black hole in a galaxy as if they were a record on a record player.Gravitational laws as we understand them don't seem to apply.Is it possible that a black holes gravitational pull not only freezes light from our perspective but also freezes time?
Astronomy news on Phys.org
HUH? What makes you think that? Gravitational laws as we understand them EXACTLY explain all that. Also, you have your facts wrong. Stars orbiting a black hole are generally (possibly all) in long elliptical orbits, not circular like on a record player.
Now that's just silly. You yourself just said that we can see the stars in orbit around a black hole (which we can) so how could that be if time were frozen?
@Wallsy I see from other threads that you have posted here before regarding your lack of understanding of cosmology in general and orbital mechanics in particular. You would be well served to read up on this stuff systematically instead of asking semi-random questions on an internet forum.
Likes berkeman
It's also worth noting that the galaxy does not orbit the black hole in the same way that the planets orbit the sun. The sun is a thousand times more massive than everything else in the solar system combined. The SMBH is the center of the Milky Way is significantly less massive than the rest of the galaxy.
Anyway, the answer is that there is additional stuff in the galaxies that we can't see called dark matter. We know it exists by various means (not just the orbital velocity problem) but we don't have any maths that can describe what it is yet.
Yes, the vortex rotation of these galaxies you describe, is a bit strange. Have you noticed - that the best, clearest example of this type of rotation appears to be associated with the galaxies classified as ... Barred Galaxies. Go look up pictures of this type of galaxy. (They're very beautiful, photogenic.)
Now normally this rotation would be classified as a 'Rankine Vortex', with an inner, central Forced Vortex rotation component, and a second, outer, Free Vortex Rotation component.
In these galaxies, the Forced Vortex rotation is as expected ... but the Free Vortex rotation section does not have the correct rotation velocity signature. Instead of having the normally expected, 2'nd order, power decay equation/line ... the decay is almost non-existent - almost horizontal.
So, it is really the outer portion of the vortex that is not performing as expected. Its orbital velocity is way too fast - for the amount of visible matter present.
Astronomers came up with a solution to this problem - called 'Dark Matter'. It has real magical properties.
The Forced Vortex portion of the Galaxy's vortex, has another Physical property that must be considered and looked it. The Forced Vortex 'conserves angular rotation' ... the old picture of the beautiful ice skater speeding up or slowing way down depending upon if she extends her arms outwards or pulls them vertically up along her rotating z-axis as close as possible.
What this means is that a Barred Galaxy is probably not operating in steady-state mode. Instead, it is slowly decaying ... which in this case means that every time the central Black Hole swallows and eats one of its orbiting stars - the Forced Vortex, to conserve angular rotation ... ejects a star or star mass, off of the ends of the central Bar-of-Light.
This conserves the angular rotation rate and energy of the Forced Vortex. Meanwhile, the ejected star(s) fly outwards. Then, according to orbital rotation mechanics - flow backwards.
Look at the pictures of Barred Galaxies again. See this "flow of stars" ... as 'two', beautiful, spiral arms ... One off of each of the two ends of the Light Bar ... as the stars flow upwards and backwards.
Related to The bizarre rotation of galaxies
1. What is "The bizarre rotation of galaxies"?
"The bizarre rotation of galaxies" refers to the observation that the outer regions of galaxies rotate at the same speed as the inner regions, despite the fact that the outer regions are much farther from the galactic center and should therefore rotate slower according to the laws of gravity.
2. What causes this bizarre rotation?
The cause of this bizarre rotation is still not fully understood, but it is believed to be due to the presence of dark matter. Dark matter is a mysterious substance that does not emit or absorb light, but can be detected through its gravitational effects on visible matter. It is thought that the gravitational pull of dark matter is what keeps the outer regions of galaxies rotating at the same speed as the inner regions.
3. How do scientists study the rotation of galaxies?
Scientists study the rotation of galaxies through a technique called spectroscopy. This involves using telescopes to collect the light from stars and other objects in a galaxy, and then breaking that light into its component wavelengths. By analyzing the patterns and shifts of these wavelengths, scientists can determine the speed at which the galaxy is rotating.
4. Are all galaxies affected by this bizarre rotation?
Most spiral galaxies, including our own Milky Way, exhibit this bizarre rotation. However, other types of galaxies, such as elliptical and irregular galaxies, do not have clearly defined rotation patterns and are not affected in the same way.
5. What are the implications of this bizarre rotation for our understanding of the universe?
The bizarre rotation of galaxies challenges our current understanding of gravity and the distribution of matter in the universe. It also supports the theory of dark matter and highlights the need for further research and exploration into this mysterious substance. Understanding the bizarre rotation of galaxies could ultimately lead to a better understanding of the structure and evolution of the universe as a whole.
  • Astronomy and Astrophysics
