The CMB drag on an object moving through space
In summary: If you have further questions, please post in an existing thread or start a new one on the appropriate forum.
JimJCW
40
An object moving through a fluid, such as the air, experiences a pressure drag caused by the difference in fluid pressure between the front and back surfaces of the object. Similarly, an object moving through a thermalized photon gas, such as the CMB, also experiences a drag. The cause in this case is that the object sees a blue shifted photon gas along the direction of motion and a redshifted one in the opposite direction (see Smith 1995, The drag on a sphere moving through a blackbody radiation bath). An example of this effect is the observed CMB dipole: The Earth travels at about 370 km/s relative to the CMB (see Planck 2018). In the all-sky map from the COBE satellite, radiation in the Earth's direction of motion appears 0.35 mK hotter than the average temperature, 2.725 K, while radiation on the opposite side of the sky is 0.35 mK cooler. The pressure of a thermalized photon gas is related to its temperature T by
https://www.physicsforums.com/attachments/288905
The observed CMB dipole, therefore, implies a radiation pressure difference between the two sides of the earth, causing a CMB drag on it. By plugging in suitable estimates of quantities involved, such as the cross-section of the Earth and the temperatures on the two sides, 2.725K + 0.35mK and 2.725K - 0.35mK, this drag can be estimated to be tiny,
https://www.physicsforums.com/attachments/288906
For comparison, please note that,
https://www.physicsforums.com/attachments/288908
For a photon traveling at 300,000 km/s through space, could there be a CMB drag too? How can we get some ideas about this?
Space news on Phys.org
No. Photon-photon interaction is negligible at CMB energies. A photon is not a little billiard ball.
Even if CMB photons did interact with one another, they'd just redistribute energy between one another, retaining the same thermal distribution. Drag doesn't make sense here, because drag implies a loss of energy. If CMB photons did interact, any "lost" energy in such an interaction would end up being picked up by another CMB photon.
So even if they did behave like billiard balls, drag still wouldn't make sense.
Drag from the CMB does make sense, however, when considering very high-energy particles, especially charged particles.
Likes Delta2
We are considering an optical photon traveling through the CMB photon gas, similar to what you said, “Drag from the CMB does make sense, however, when considering very high-energy particles, …” In the present case, by drag, I mean that on the optical photon.
Photon-photon scattering is allowed by quantum electrodynamics through virtual electron-positron pair. The interaction between the traveling photon and the photon gas is, therefore, unavoidable when it travels through the CMB; the question is how much. PeterDonis thinks it is negligible.
  • Sad
Likes weirdoguy
I found this:
https://inspirehep.net/files/4aa16cf428ef41062d0fafa026485c01
We've been through this before in your previous, now locked, thread. There's more scattering in the lens of your eye than in photon-photon scattering in the entire universe.
Since you clearly don't believe the answers you are getting, I can only conclude you are not seeking information - you are instead pushing your own personal theory.
Likes weirdoguy
It's not a matter of what I personally think. As @Vanadium 50 has pointed out, we already discussed this in a previous thread of yours, which has been closed. So this thread is closed as well.
FAQ: The CMB drag on an object moving through space
What is the CMB drag?
The CMB drag, also known as the Cosmic Microwave Background drag, is the phenomenon where an object moving through space experiences a drag force due to its interaction with the photons of the Cosmic Microwave Background radiation.
How does the CMB drag affect objects in space?
The CMB drag can affect objects in space by slowing down their motion and causing them to lose energy. This can be particularly significant for objects moving at high speeds, such as spacecraft or galaxies.
What causes the CMB drag?
The CMB drag is caused by the interaction between an object's motion and the photons of the Cosmic Microwave Background radiation. As the object moves through space, it collides with these photons, transferring some of its energy to them and experiencing a drag force in return.
Can the CMB drag be measured?
Yes, the CMB drag can be measured through various techniques, such as studying the motion of objects in space or analyzing the anisotropies in the Cosmic Microwave Background radiation. These measurements can provide valuable insights into the properties of the CMB and the dynamics of objects in the universe.
How does the CMB drag impact our understanding of the universe?
The CMB drag is an important factor in our understanding of the universe, as it contributes to the overall dynamics and evolution of objects in space. By studying the CMB drag, scientists can gain a better understanding of the composition and behavior of the universe, as well as its origins and future. Additionally, the CMB drag can also help test and refine theories such as general relativity and the standard model of cosmology.
