The Cochran and Cox Approximation Pair T test Unequal Variance
In summary: Thus, we have derived the Cochran-Cox approximation for the probability level of the approximate t statistic. I hope this helps!
mertcan
345
Hi everyone I hope you are well. Maybe as you know according to Behners-Fisher problem (unequal variance case of samples) there are some kind of approximations. I have recently covered the Satterthweiths Approximations and comprehended the logic of it. But I got stuck with the Cochran-Cox approximation which is the following: Approximation of the probability level of the approximate t statistic is the value of p such that $$t^{'} = \frac {\bar x_1-\bar x_2} {\sqrt { s_1^2/n1 + s_2^2/n2}} =(s_1^2/n1*t_1+s_2^2/n2*t_2)/(s_1^2/n1+s_2^2/n2)$$
where t1 and t2 are the critical values of the t distribution corresponding to a significance level of p and sample sizes of n1 and n2, respectively besides s_1 and s_2 are corresponds to sample variances. The number of degrees of freedom is undefined when n1=!n2. Could you help me derive it?
Hello,
Thank you for your post. The Cochran-Cox approximation is a method used to approximate the probability level of the t statistic in cases where the samples have unequal variances. It is derived from the Behrens-Fisher problem, which deals with the comparison of means from two populations with unequal variances.
To derive the Cochran-Cox approximation, we start with the t statistic formula:
$$t = \frac {\bar x_1 - \bar x_2} {\sqrt {\frac {s_1^2} {n_1} + \frac {s_2^2} {n_2}}}$$
We can then rewrite this formula as:
$$t = \frac {(\bar x_1 - \bar x_2) \sqrt {n_1 + n_2}} {\sqrt {s_1^2 + s_2^2}}$$
Next, we substitute the sample variances with their corresponding critical values from the t distribution:
$$t = \frac {(\bar x_1 - \bar x_2) \sqrt {n_1 + n_2}} {\sqrt {s_1^2 + s_2^2}} = \frac {(\bar x_1 - \bar x_2) \sqrt {n_1 + n_2}} {\sqrt {\frac {(n_1 - 1) s_1^2 + (n_2 - 1) s_2^2} {n_1 + n_2 - 2}}}$$
We can then simplify this formula to:
$$t = \frac {(\bar x_1 - \bar x_2) \sqrt {n_1 + n_2}} {\sqrt {(n_1 - 1) s_1^2 + (n_2 - 1) s_2^2}} = \frac {(\bar x_1 - \bar x_2) \sqrt {n_1 + n_2}} {\sqrt {\frac {n_1 s_1^2 + n_2 s_2^2} {n_1 + n_2 - 2}}}$$
Finally, we can use the Satterthwaite approximation to further simplify this formula:
Related to The Cochran and Cox Approximation Pair T test Unequal Variance
1. What is the Cochran and Cox Approximation Pair T test for unequal variance?
The Cochran and Cox Approximation Pair T test is a statistical test used to compare the means of two groups when the variances of the two groups are unequal. It is an extension of the paired t-test, which is used when the variances are equal. This test is commonly used in scientific research to determine if there is a significant difference between two groups.
2. How does the Cochran and Cox Approximation Pair T test work?
The test works by comparing the difference between the means of the two groups to the standard error of the difference. This standard error takes into account the unequal variances of the two groups. The test then calculates a t-statistic, which is compared to a critical value from a t-distribution. If the t-statistic is greater than the critical value, then there is a significant difference between the two groups.
3. When should the Cochran and Cox Approximation Pair T test be used?
This test should be used when comparing the means of two groups with unequal variances. It is commonly used in situations where the variances of the two groups are not equal, but the sample sizes are relatively small. This test is also appropriate when the data is normally distributed.
4. What are the assumptions of the Cochran and Cox Approximation Pair T test?
The assumptions of this test are similar to those of the paired t-test. The data should be normally distributed, the samples should be independent, and the variances of the two groups should be unequal. Additionally, the data should be measured on a continuous scale and the two groups should have the same number of observations.
5. What are the advantages of using the Cochran and Cox Approximation Pair T test?
One advantage of this test is that it allows for the comparison of means when the variances of the two groups are unequal. This is important because using a standard paired t-test in this situation can lead to incorrect conclusions. Additionally, this test is appropriate for small sample sizes and does not require the assumption of equal variances, which can be difficult to meet in practice.
