The consistency of linear systems
In summary: You do seem to be getting full rank. But that's because you are doing it wrong. It doesn't have full rank. Do the operations one at a time and specify the row you are substituting for. If you wind up with a row of zeros, then you should...
MoreDrinks
45
What conditions do x, y and z need to fulfill for the system of equations to be consistent?
2a + 3b + 5c = x
a + 3c = y
a - b + c = z
Not quite sure. The notion of consistency was never discussed in class, nor is it addressed in the linear algebra text. I understand that it simply means having some sort of solution, and that inconsistency means not having any sort of solution - but examples almost always give integers on the right sides of the equations so that you can reduce the rows and see if there's a contradiction (such as 0+0+0=1) or not.
Is it just "If a, b and c are zero, then x, y and z must not be other than zero" or something of that nature?
Have you learned about matrices yet? If so, row reduce the matrix until you reach row reduced echelon form. Then use your example of "0 + 0 + 0 = 1", which is an inconsistent solution, to find out which values for x,y, and z the system is consistent.
2a + 3b + 5c = x
a + 3c = y
a - b + c = z
a, b and c are the variables you want to solve for. So the rows are [2,3,5], [1,0,3] and [1,-1,1]. Yes, reduce them to see if there might be any requirements on x, y and z to get consistency.
I think I get it. Thanks.
But it would seem that to do this, one would need to use an augmented matrix, right? And in that case, isn't it going to be difficult or impossible to isolate x, y and z in order to see what requirements there might be?
You could do that. But if you reduce the matrix of just the coefficients and you get that it has full rank, i.e. no zero rows, then there will be no requirements for consistency on x, y and z. Yes? It wouldn't matter much what happens on the augmented side. I think you will get full rank. If I did it right.
Thank you. There's one other where I do not seem to be getting full rank:
1 0 2
2 1 5
1-1 1
First operations: -2R1+R2, -R1+R3
1 0 2
0 0 1
0-1-1
Actually, would the following work? -R3+R2, R2+R1
1 0 2
0 1 2
0 0 1
then using the final row to eliminate the 2's?
1 0 2
2 1 5
1-1 1
1 0 2
0 0 1
0-1-1
1 0 2
0 1 2
0 0 1
You do seem to be getting full rank. But that's because you are doing it wrong. It doesn't have full rank. Do the operations one at a time and specify the row you are substituting for. If you wind up with a row of zeros, then you should do the augmented matrix. The expressions in x, y and z in the rows with all zeros are your consistency constraints.
Ahh. By not screwing up the very first operation, it seems to go like so
1 0 2 x
2 1 5 y
1-1 1 z
Add -2R1 to R2
1 0 2 x
0 1 1 y-2x
1-1 1 z
then add -R2 to R3
1 0 2 x
0 1 1 y-2x
0-1-1 z-x
then finally, add R2 to R3
1 0 2 x
0 1 1 y-2x
0 0 0 z-3x+y
So the constraint would be z-3x+y = 0, or else the system is inconsistent.
1 0 2 x
2 1 5 y
1-1 1 z
Add -2R1 to R2
1 0 2 x
0 1 1 y-2x
1-1 1 z
then add -R2 to R3
1 0 2 x
0 1 1 y-2x
0-1-1 z-x
1 0 2 x
0 1 1 y-2x
0 0 0 z-3x+y
Yes, but you meant add -R1 to R3 in the second step, yes?
Yes, sorry. I'm exhausted. Thank you!
Me too. But you did it right. That's what counts. Very welcome!
FAQ: The consistency of linear systems
What is the definition of consistency in linear systems?
Consistency in linear systems refers to the property of a system of linear equations having at least one solution. This means that the system of equations has a unique set of values for the variables that satisfy all the equations simultaneously.
How can you determine if a linear system is consistent or inconsistent?
A linear system is consistent if it has at least one solution. This can be determined by using methods such as Gaussian elimination or matrix operations to solve the system and see if a solution exists. If no solution exists, the system is inconsistent.
What does it mean if a linear system is consistent but has infinitely many solutions?
If a linear system is consistent but has infinitely many solutions, it means that there are an infinite number of possible combinations of values for the variables that satisfy the system of equations. This typically occurs when there are more variables than equations in the system.
How does the number of equations and variables affect the consistency of a linear system?
If the number of equations is equal to the number of variables in a linear system, it is more likely to be consistent. However, if there are more variables than equations, the system may still be consistent but have infinitely many solutions. If there are more equations than variables, the system is likely to be inconsistent.
Can a consistent linear system have no solution?
No, a consistent linear system must have at least one solution. If no solution exists, the system is inconsistent. This means that the equations are contradictory and cannot be satisfied simultaneously.
