The convergence Criteria ratio
Amaelle
is the serie convergent or absolutely convergent?
Greetings all
I have a question regarding the convergence criteria ratio, abs(an+1/an) or the n√abs(an) when the limit tend to a value less than 1 does it mean the serie is convergent or absolutely convergent?
Thank you!
If the limit is less than 1, the series is absolutely convergent. It is only if the limit equals one that it might be convergent, but not absolutely convergent.
thank you!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
