The curve formed by the intersection of paraboloid and ellipsoid
In summary, the problem is that the tangent vector at point p(x1,y1,z1) on the curve formed from paraboloid intersection with ellipsoid should be the same as the tangent vector at same point on paraboloid and ellipsoid, but it is undefined. I need to find the parametric equations for this tangent line.
clairaut
72
I will state the specifics to this problem if necessary.
I need to find the parametric equations for the the tan line at point, P(x1,y1,z1) on the curve formed from paraboloid intersection with ellipsoid.
The parametric equations for the level surfaces that make up paraboloid and ellipsoid are NOT given.
The level functions for paraboloid and the level function for ellipsoid are given.
This is what I've done so far.
I found the equation of the curve that forms from the intersection.
[c(x,y)] = curve of paraboloid and ellipsoid intersection.
The tangent vector at p(x1,y1,z1) on curve should be the same as the tangent vector at same point on paraboloid and ellipsoid.
I have taken the gradient of curve dot tangent vector = 0
I have taken the gradient of level fxn of paraboloid dot tangent vector = 0
I have taken the gradient of level fxn of ellipsoid dot tangent vector = 0Solving the three linear equations that all equal to zero gets me nowhere. I am stuck. Help me.
The problem is that it "should be the same as" a tangent vector to the paraboloid and ellipsoid. A smooth surface, such as a paraboloid or ellipsoid, has a tangent surface at each point, so an infinite number of tangent vectors.
I don't know what you mean by the gradient of a curve. And which tangent vector do you mean here?
Again, I don't know which tangent vector you mean.
The tangent vector at point p(x1,y1,z1) on paraboloid is the same as the tangent vector at point p(x1,y1,z1) on ellipsoid and same as the tangent vector at Point P(x1,y1,x1) on curve, [c(x,y)]
This tangent vector is NOT defined and I have to find the parametric equations for this tangent line.
Gradient of [c(x,y)]
Remember... [c(x,y)] = curve that forms from intersection between paraboloid and ellipsoid
The tangent vector is what I'm supposed to find. The tangent vector at point P(x1,y1,z1)
Again, it is the tangent vector that is undefined in the problem.
Am I correct with all my statements above?
Unless you are given the parameter, you must mean you need to find some parametric equations. There could be many ways of parameterising it.
I think Halls' problem with that statement is that it reads as though there is a well-defined tangent vector at a given point on a paraboloid etc. You probably mean
The tangent vector at p(x1,y1,z1) on curve should be a tangent vector at same point on paraboloid and ellipsoid.​
Halls and I are puzzled by that statement. How are you defining the gradient of a curve in 3-space?
These are the normals to the surfaces, so that sounds right. (In fact, I would have approached it by finding the tangent planes then taking the intersection.)
Please post your working as far as you got.
Is the intersection between paraboloid and ellipsoid a surface or a curve?
I have a 2nd degree polynomial in xy form for this intersection between paraboloid and ellipsoid which indicates I have a surface. However, I can't seem to accept that the intersection between paraboloid and ellipsoid is a surface.
I second Haruspex's request. Please post your original equations and your work. A polynomial in "xy form" doesn't represent anything but a polynomial. You need an equation to represent a surface. And, yes, you would expect a paraboloid and ellipsoid to intersect in a curve or curves in the typical case if they intersect at all. Please post your work.
If you have an equation involving x and y but not z, that can be thought of as the projection of the curve (not a surface) onto the XY plane. It will constitute a (presumably correct) statement about the relationship of y to x along the 3D curve (line). You could go back to your surface equations and eliminate y instead, giving you an equation in x and z. That will be the projection of the curve onto the XZ plane.
Here is the exact problem.
Paraboloid [z(x,y)] = x^2 + y^2
Ellipsoid 4x^2 + y^2 + z^2 =9
Find parametric equations for tangent line to the curve of intersection of paraboloid and ellipsoid at point P(-1,1,2)My work done so far.
The curve of intersection is
[C(x,y)] = 4x^2 + y^2 + x^4 + 2x^2 y^2 + y^4 = 9
Gradient of [C(x,y)] dot tangent vector = 0
Yes or no?
Gradient of ellipsoid, [E(x,y,z)] dot tangent vector = 0
Yes or no?
Gradient of [C(x,y)] dot tangent vector = 0?
That is not the equation of the curve of intersection. That is the equation of a cylindrical surface in 3D which passes through the curve of intersection of the surfaces. It is also the 2D equation of the projection of that curve onto the xy plane.
But you don't need the equation of the curve in the first place. You are after the equation of its tangent line at the given point. Think about the cross product of the normals to the given surfaces at the given point. What direction would it point?
Didn't even consider the cross product.
That helps a lot!
Brb
Okay... I found that the cross product between gradient of paraboloid function and gradient of ellipsoid function at point P(-1,1,2) produces
Tangent vector T = <9/2, 6, 6>
And unit tangent vector = <3/41 * rad41 , 4/41 * rad41, 4/41 * rad41>Thus,
Parametric equation for tangent line is
-1 + 3/41 rad41 t = [x(t)]
1 + 4/41 rad41 t = [y(t)]
2 + 4/41 rad41 t = [z(t)]This does NOT match answer in back of book.
HELP ME
Not what I get. Please post your working.
Paraboloid
D(x,y,z) = (z^-1) (x^2 + y^2) = 1
ELLIPSOID
L(x,y,z) = 4x^2 + y^2 + z^2 = 9Gradient of paraboloid at P(-1,1,2)
<-1,1,-1/4>
Gradient of ellipsoid at P(-1,1,2)
<-8,2,4>
Cross these two to get
<9/2,6,6>
Help. I am stuck
Okay!
I am close to the answer, but I need a fresh outlook from some new brains.
Curve of intersection is
C(x,y) = x^4 + 4x^2 + 2x^2 y^2 + y^4 + y^2 = 9
Gradient of C(x,y) is
<-16,10,0>
Cross gradient of ELLIPSOID to gradient of curve and I get
8 * <-5,-8,-6>I'm not sure why I can't simple cross gradient of paraboloid and ellipsoid to get same as above.
The answer says
X = -1 - 10t
Y = 1 - 16t
Z = 2 - 12tMy answer says
X=-1-5t
Y=1-8t
Z=2-6t
I'm quite sure my answer is the same as the answer in textbook for this parametric equation of tangent line.
Yes or no?
2 questions.
1. Why can't I cross gradient of paraboloid to gradient of curve of intersection?2. Why can't I simply cross gradient of paraboloid to gradient of ellipsoid to get the right answer?
IT IS NECESSARY TO CROSS ELLIPSOID GRADIENT TO CURVE GRADIENT.
WEIRD!
clairaut said:
Paraboloid
Your paraboloid is ##z = x^2+y^2## or ##x^2+y^2 - z = 0##. Easier than what you wrote.
clairaut said:
The answer says
X = -1 - 10t
Y = 1 - 16t
Z = 2 - 12t
My answer says
X=-1-5t
Y=1-8t
Z=2-6t
Yes or no?
Yes. Your direction vector is a constant multiple of theirs. Just different parameterizations of the same line.
Yes! I get it now!
The ellipsoid and curve of intersection are level fxns while the paraboloid isn't. Paraboloid gradient dot tangent vector does NOT equal zero!
clairaut said:
Yes! I get it now!
Huh?? The tangent vector to the curve of intersection is in the direction of the cross product of the gradients of the two surfaces at that point. Therefore the tangent vector is perpendicular to both gradients.
No. Wrong
clairaut said:
No. Wrong
What are you saying is wrong?
FAQ: The curve formed by the intersection of paraboloid and ellipsoid
1. What is the mathematical definition of a paraboloid and an ellipsoid?
A paraboloid is a three-dimensional surface that is shaped like a bowl or a vase, with a central point called the focus. An ellipsoid is also a three-dimensional surface, but it is shaped like an egg or a football, with three unequal axes of rotation.
2. How are paraboloids and ellipsoids related?
The curve formed by the intersection of a paraboloid and an ellipsoid is a special type of curve known as a conic section. This means that the curve is created by the intersection of a plane with a cone. In this case, the plane intersects both the paraboloid and the ellipsoid, resulting in a unique curve.
3. What is the significance of the curve formed by the intersection of a paraboloid and an ellipsoid?
This curve has many practical applications in engineering, physics, and mathematics. It is used to model and analyze various physical phenomena, such as the shape of satellite dishes, the trajectory of projectiles, and the orbits of celestial bodies.
4. Can the curve formed by the intersection of a paraboloid and an ellipsoid be represented by a mathematical equation?
Yes, the curve can be represented by a single equation that combines the equations for the paraboloid and the ellipsoid. This equation is known as a parametric equation and it allows us to calculate the coordinates of points on the curve.
5. Are there any real-life examples of the curve formed by the intersection of a paraboloid and an ellipsoid?
One famous example is the shape of the St. Louis Gateway Arch, which is a paraboloid and an ellipsoid intersecting each other. Additionally, the shape of satellite dishes and the trajectory of projectiles can be modeled using this curve.
