The definition and causes of the Coanda effect
  • Thread starter Fluids
  • Tags
    Definition
In summary, the Coanda effect is not the same as normal boundary layer attachment to a surface. It is also not limited to only convex surfaces over which a jet is blown tangentially. The Coanda effect is caused by a combination of the jet entraining the ambient fluid and a balance of pressure and centrifugal forces. For further information, it may be helpful to consult textbooks or papers on fluid dynamics.
Fluids
I am confused about the following points regarding the definition and causes of the Coanda effect:
  • whether the Coanda effect is the same as normal boundary layer attachment to a surface
  • whether the Coanda effect is only defined for convex surfaces over which a jet (of the same state as the surrounding fluid) is tangentially blown
  • what causes the Coanda effect: the jet entraining the ambient fluid or a balance of pressure and centrifugal forces, or something else?
Any answers to these, or recommendations of useful textbooks/papers, would be much appreciated.
Thanks.
The Coandă effect is the tendency of a moving flow to follow the contour of a surface it is in contacting. One way to think of it is the fact that nature abhors a vacuum. Assume that a flow does not follow the contour of a surface for a second: the air would pass over the surface and as the surface begins to fall away, the flow would tend to entrain the fluid that is near the surface, pulling it along with the flow. That would tend to create a vacuum against the wall, so the flow will seek to find equilibrium by coming back to the wall. This would theoretically apply to a concave surface as well, but I can't think of any situations where you would actually see it since there is usually a strong favorable pressure gradient that would tend to hold the flow against the surface anyway.
This is not the same as the boundary layer, which has to do with fluid particles near the wall not slipping against the wall. This gives rise to the boundary layer. Interestingly, the Coandă effect can be overcome if the boundary layer has a strong enough pressure gradient retarding its motion. Then the boundary layer can "separate" and pull away from the surface. It overcomes the Coandă effect by pulling fluid in backward from upstream, creating a sort of bubble of circulating fluid against the surface.
Related to The definition and causes of the Coanda effect
1. What is the Coanda effect?
The Coanda effect is a phenomenon where a fluid or gas flowing over a curved surface tends to follow the contour of the surface instead of continuing in a straight line.
2. What are the causes of the Coanda effect?
The Coanda effect is caused by fluid or gas particles adhering to the surface of the curved object due to the difference in pressure between the upper and lower surfaces. This results in the particles following the curved surface instead of continuing in a straight line.
3. How was the Coanda effect discovered?
The Coanda effect was first observed and documented by Romanian aerodynamics pioneer Henri Coanda in 1910 during his experiments with a jet engine prototype. He noticed that the exhaust flow of the engine curved towards nearby surfaces instead of dissipating into the atmosphere.
4. What are the practical applications of the Coanda effect?
The Coanda effect has many practical applications in various industries such as aviation, engineering, and medicine. It is used in aircraft design to improve lift and control, in industrial processes such as coating and drying, and in medical devices such as nebulizers.
5. How does the Coanda effect affect aerodynamics?
The Coanda effect plays a significant role in aerodynamics, particularly in the design of aircraft wings and airfoils. By utilizing the Coanda effect, engineers can manipulate the airflow over these surfaces to improve lift, reduce drag, and control the direction of the aircraft.
  • Mechanical Engineering
  • Other Physics Topics
  • Classical Physics
