The definition of pascal confused
In summary, 1 pascal is equivalent to 1 Newton per squared meter, and 2 pascals is equal to 2 Newtons per squared meter. However, 2 Newtons per 2 squared meter is incorrect as it simplifies to 1 Newton per square meter. This can be understood by representing the 2 as a fraction and multiplying it with the units. Ultimately, any fraction representing 2 will always simplify to 2kg/ms2, or 2 pascals.
Femme_physics
So 1 pascal is 1 Newton per squared meter
Are 2 pascals 2 Newtons per squared meter, or 2 Newtons per 2 squared meter applied on the object?
2 Newtons per squared meter - correct.
2 Newtons per 2 squared meter - wrong.
Think about it, 2 Newtons per 2 squared meter = 1N per square meter.
Right it out with the units and you'll see that by applying it to the top and bottom cancels out to leave you with 1N per square meter always.
Pascal = kg / m s2
2 Pascal = (2/1) x (kg / m s2) = 2kg / ms2
Picture the 2 as a fraction = 2/1. Multiply that fraction out with the units and you get your answer.
It doesn't matter what fraction you represent the two with (2/1, 4/2, 8/4, 1/0.5 etc) you will always come back to: 2kg / ms2 = 2Pa
To get 2 Newtons per 2 squared meter, you'd need the fraction to be 2/2 Pa = 1 Pa.
Not the worlds greatest explanation, but that's how I work it out and check it.
Yes, I had this silly thought of it being a measure of how many 1 Newtons per 1 squared meter are applied over a general area...but since this general area is defined as 1 squared meter already, that resolves it!
Related to The definition of pascal confused
1. What is the definition of pascal confused?
The definition of pascal confused refers to a common misconception or confusion regarding the unit of pressure called pascal. Some people may confuse it with the name of the famous mathematician Blaise Pascal.
2. Is pascal confused a scientific term?
No, pascal confused is not a scientific term. It is simply a way to describe a confusion or misunderstanding related to the unit of pressure called pascal.
3. What is the correct definition of pascal?
The pascal is the SI unit of pressure, defined as one newton per square meter. It is named after the French mathematician and physicist Blaise Pascal.
4. How is pascal confused different from Blaise Pascal?
Pascal confused is not a person, but a term used to describe a misconception about the unit of pressure called pascal. Blaise Pascal, on the other hand, was a famous mathematician, physicist, and philosopher from the 17th century.
5. Why is it important to understand the correct definition of pascal?
Understanding the correct definition of pascal is important because it is a widely used unit of pressure in scientific and engineering fields. Using the correct definition ensures accurate and consistent measurements and calculations.
  • Other Physics Topics
  • Classical Physics
  • General Math
