The definition of “vector” in math and physics
In summary, a vector is a mathematical structure used to represent data in arrays. It can have different definitions depending on the field of study, but it is typically an ordered list of numbers. In physics, a vector is a directed magnitude, but not all physical quantities that can be treated as vectors have a magnitude and direction.
Zeynel
43
I'm learning APL and this is how a vector is defined https://tryapl.org:
All data resides in arrays. An array is a rectangular collection of numbers, characters and arrays, arranged along zero or more axes. We can use more specific terms for some arrays, like a single number is a scalar, a list is a vector, and 2D arrays are matrices. Vectors can be formed by just placing elements next to each other:​
I see that in math a list of numbers is called a vector.
In physics a vector is a directed magnitude. So vector in physics is a set of only two numbers. One of these numbers is interpreted as magnitude and the other is interpreted as direction.
My question is: Is the above description correct?
Mathematics news on Phys.org
This is not a correct conclusion. Direction cannot be described by a single number (unless you are just looking at two dimensions).
Vectors are more formally treated in a discipline known as "linear algebra". It turns out that the ability to treat a vector as a one dimensional array of numbers can then be traced to being able to identify a "basis" for a vector space. Individual vectors within the space can then be identified with unique linear combinations of basis vectors and the linear combination can [sometimes] be described as a one dimensional array of numbers.
https://en.wikipedia.org/wiki/Vector_space
At various stages of our education, we learn different definitions for the same word. Different definitions for the same word are used in different fields of study. So you can expect to hear different definitions of the word "vector".
As @jbriggs444 indicates, from an advanced point of view, a vector is an element of a mathematical structure that satisfies certain axioms. An ordered list of numbers is one example of a vector but an ordered list of numbers is not the only example of a vector. When you say "A vector is... such-and-such", you must think about whether your are saying a vector is identical to something or whether it is merely one example of something.
Not all physical quantities that can be treated as vectors have a "magnitude and direction". Those that do have a magnitude and direction can usually be regarded as vectors.
Likes jbriggs444
Related to The definition of “vector” in math and physics
1. What is the definition of a vector in math and physics?
A vector is a mathematical quantity that has both magnitude (size) and direction. It is represented by an arrow pointing in the direction of the vector, with the length of the arrow representing the magnitude of the vector.
2. How is a vector different from a scalar?
A scalar is a mathematical quantity that only has magnitude, while a vector has both magnitude and direction. For example, temperature is a scalar quantity, while velocity is a vector quantity.
3. Can a vector be negative?
Yes, a vector can be negative. This means that the direction of the vector is in the opposite direction of the positive vector. For example, a vector pointing east would have a positive direction, while a vector pointing west would have a negative direction.
4. What is the difference between displacement and distance in terms of vectors?
Displacement is a vector quantity that represents the change in position from an initial point to a final point. It has both magnitude and direction. Distance, on the other hand, is a scalar quantity that only represents the total length of the path traveled, regardless of direction.
5. How are vectors used in physics?
Vectors are used in physics to represent physical quantities such as force, velocity, and acceleration. They allow us to understand the direction and magnitude of these quantities, which are essential in understanding and analyzing physical phenomena. Vectors are also used in mathematical calculations, such as finding the resultant vector of multiple forces acting on an object.
  • General Math
  • Classical Physics
  • STEM Academic Advising
  • Linear and Abstract Algebra
