MHB The Determinant of a Matrix with n+1 Ones: Is It Always -1, 0, or 1?
mathmari
MHB
Hey! :o
Let $A \in\mathbb{R}^{n\times n}$, $n\geq 3$ be a matrix with $n+1$ elements $1$ and the remaining elements are $0$. I want to show that $\det (A)\in \{-1, 0, 1\}$ and each of these $3$ possible values can occur.
Could you give me a hint how we could show that? I got stuck right now. (Wondering)
mathmari said:
Hey! :o
Hey mathmari! (Smile)
What about induction?
We can include the 2x2 matrix for which it also holds true.
Did you know that we can evaluate any determinant like this:
$$\begin{vmatrix} a & b & c & d\\e & f & g & h\\i & j & k & l\\m & n & o & p \end{vmatrix}=a\,\begin{vmatrix} f & g & h\\j & k & l\\n & o & p \end{vmatrix}-b\,\begin{vmatrix} e & g & h\\i & k & l\\m & o & p \end{vmatrix}+c\,\begin{vmatrix} e & f & h\\i & j & l\\m & n & p \end{vmatrix}-d\,\begin{vmatrix} e & f & g\\i & j & k\\m & n & o \end{vmatrix}$$
(Wondering)
(Wondering)
Base case:
For $n=2$ we have that $\begin{vmatrix} a & b \\ c & d\end{vmatrix}=ad-bc$.
Since $n+1=3$ elements are equal to $1$ we have that one element is $0$. That means that the result is either $1$ or $-1$.
For $n=3$ we have that $\begin{vmatrix} a & b & c\\ d & e & f \\ g & h & i\end{vmatrix}=a\,\begin{vmatrix} e & f \\ h & i\end{vmatrix}-b\,\begin{vmatrix} d & f \\g & i \end{vmatrix}+c\,\begin{vmatrix} d & e\\g & h \end{vmatrix}$.
Since $n+1=4$ elements are equal to $1$ we have that $9$ elements are equal to $0$.
If $a=b=c=0$ then the result is equal to $0$.
If at least one of the $a,b,c,d$ is non-zero, then we have from the previous case that the $2\times 2$ determinants will be equal to $1$ or $-1$. Therefore, the $3\times 3$ determinant will be equal to $-1$, $0$ or $1$.
Is this correct? Or could we improve the justification? (Wondering) Inductive hypothesis:
We suppose that $n\times n$ determinant will is equal to $-1$, $0$ or $1$. Inductive step:
The expansion of Laplace allows to reduce the computation of the $(n+1)\times (n+1)$ determinant to that of $n+1$ $(n\times n)$ determinants.
These $n+1$ determinants are equal to $-1$, $0$ or $1$.
We have $n+2$ elements that are equal to $1$ and the remaining ones are $0$.
How could we continue? I got stuck right now. (Wondering)
Let's distinguish 3 cases: the top row has only zeroes, it has exactly 1 one, or it has 2 or more ones... (Thinking)
If the top row has only zeroes, then the determinant of $A$ is equal to $0$.
If the top row has exactly 1 one, then the determinant is equal to determinant of the $n\times n$ submatrix, of which the coefficient is $1$. From the inductive hypothesis we get that this will be equal to $-1$, $0$ or $1$, right? (Wondering)
If the top row has 2 or more ones, then the determinant of $A$ is equal to the determinant of the 2 or more $n$-submatrices. These, from the inductive hypothesis, will be equal to $-1$, $0$ or $1$. How do we know that the result is not $2$ for example? (Wondering)
Isn't the inductive hypothesis that an nxn matrix with n+1 ones is -1,0, or 1?
What if an nxn matrix has n ones? Or less than n ones?
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
