I The determination of a particle's spin
  • I
  • Thread starter Thread starter Randall71284
    Determination Spin
Randall71284
If I am unable to distinguish the spin of a particle in an absence of an electric field or magnetic field, how am I able to determine whether there is an electric or magnetic field in a real-life context?
How is it that we can be sure of the uncertainty of the spin of particles if we are unable to create a situation in which there is an absence of an electric or magnetic field?
If a small enough field could be ignored (as there still are fields, however small in magnitude, acting on every particle in the universe), is there a level of magnitude in which the electromagnetic fields can be deemed insignificant that the particle’s spin is unaffected?
I don't understand what you mean. How else do you want to measure the spin of your particle than with applying some electromagnetic field?
I mean that if we could only measure the spin of a particle by applying an electromagnetic field, and since there must be an effect on the particle by some electromagnetic field, then is there a point in saying that we must apply some electromagnetic field to measure it? Will there be any uncertainty in a particle's spin?
I'm also not sure what you're asking. QM says that a particle's spin (relative to any given axis) is indeterminate unless you measure its spin about that axis. If you do, you get one of a set of possible discrete values. In the case of an electron, for example, you get ##\pm \dfrac \hbar 2##.
What are you asking in relation to that?
"How else do you want to measure the spin of your particle than with applying some electromagnetic field?"
Most particle spins are measured without an electrical electromagnetic field, especially neutral particles.
The neutrino spin was measured using conservation of angular momentum.
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
