I The difference between calculating energy from 1 vs. 2 magnets?
When two identical magnets interact, the field strength between them can effectively double, but the force acting on a moving magnet does not necessarily double. The energy dynamics differ from combustion scenarios, as magnets have inherent limitations based on their material properties. As magnets approach each other, the force increases significantly, potentially by 70-90% in attraction scenarios, while in opposition, the force may appear weaker at larger distances. Factors such as alignment and magnet shape also influence the force experienced. Understanding these nuances is crucial for accurate calculations in magnetic interactions.
pete94857
TL;DR Summary
For example if I know the total field strength of 1 magnet and I have another magnet exactly the same. When they interact I.e they become attracted to each other and I allow one to move towards the other, the one that is moving does it have double it's own feild strength acting on it ?
For example if I know the total field strength of 1 magnet and I have another magnet exactly the same. When they interact I.e they become attracted to each other and I allow one to move towards the other, the one that is moving does it have double it's own feild strength acting on it ? Or is it not able to use the extra feild strength provided by the other magnet
What do you think the answer is? Also, do you think that the two have differing amounts of field strength acting on them?
To be honest I'm not sure.
I know that if it were a combustion scenario and I double the fuel and air the energy would also double.
But with magnets I'm not sure, they're strange things. I'm thinking maybe the material of a magnetic only has so much potential and if you think of it like the question then maybe it will not double... but on the other hand if you stick them together the surrounding field seems to double. Hence I don't know.
I do know the feild between the magnets will double but will the force acting on the moving magnet also double ? And would it be the same for both attraction and opposition ?
Seems like in attraction it does increase the force on the moving magnet by a small 10 - 30 percentage in far field but as they get closer the percentage increases 70 - 90.
In opposition it could actually show a weaker force at larger distances but near to each other it will be more than just the force of one field.
Plus many fact such as alignment , shape of magnet etc can effect the values
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
