The difference between the binding of molecules and superconductors
In summary: Why can't we look at molecules as a macroscopic wave function?We can, but it's more complex and not necessarily more insightful. The wavefunction of a molecule is just a bunch of points, and it's not like a wave. For superconductivity to happen, the wavefunction needs to be highly degenerate, which means there are a lot of points that are close to each other. But looking at a molecule as a wavefunction is just a simplification.
annaphys
69
Molecules and superconductors bind due to overlaps of the wave functions of the electrons.
1. What is the difference between these two then?
2. Why can't we look at molecules as a macroscopic wave function?
1. Superconductors are made up of molecules (and thus atoms), that's the difference.
2. You can. Just like you could look at your cup of coffee as a macroscopic wave function.
Have I misunderstood what you're asking?
Yes you have. I would assume someone who knows about superconductivity would be able to answer the questions.
Uh, so what? That's just math.
Have you considered how to actually construct a superconductor at room temperature/pressure vs how molecules are constructed in reality? That should tell you how different they are physically.
Who is stopping you...? How you interpret the math is your job as a physicist, if this interpretation leads you to an insight, then great. Use that intuition.
Yes, my answers are blunt. Give us more, you obviously have some reason to relate the two ideas. If it's just the wavefunction overlapping idea, then my advice is don't get lost in the math.
Likes berkeman
Superconductors may be viewed at as a Bose-Einstein condensate of charged particles. In usual superconductors, the compound particles are much larger than their mean distance (weak coupling limit) . However, there are superconductors, like bipolarons, where the pairs are much smaller (strong coupling). In molecules, these pairs get bound to nuclei and localized, which destroys superfluidity and superconductivity.
Likes dextercioby
With respect to molecules, is one referring to covalent bonding as in molecules like CH4 or CO2, or even long chain hydrocarbons, as opposed to bonding in compounds of metals and semimetals (or non-metals as in O in Cuprates), some of which have superconducting properties below a certain temperature?
I was reflecting on different types of superconductors:
https://en.wikipedia.org/wiki/High-temperature_superconductivity
See also this discussion
https://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.379.721&rep=rep1&type=pdf
Likes romsofia
FAQ: The difference between the binding of molecules and superconductors
What is the difference between the binding of molecules and superconductors?
The binding of molecules refers to the force that holds atoms together to form a molecule. This force is typically electromagnetic in nature and can be either covalent, ionic, or metallic. On the other hand, superconductors are materials that have the ability to conduct electricity with zero resistance when cooled below a certain temperature, known as the critical temperature.
How does the binding of molecules differ from the binding of superconductors?
The binding of molecules is a result of the interactions between the electrons of different atoms, while the binding of superconductors is due to the formation of Cooper pairs, which are pairs of electrons that behave as one unit under certain conditions.
Can molecules exhibit superconductivity?
No, molecules cannot exhibit superconductivity. Superconductivity is a macroscopic phenomenon that requires a large number of electrons to behave in a coordinated manner, which is not possible in molecules due to their small size and limited number of electrons.
What is the role of electron pairing in superconductors?
Electron pairing is a crucial aspect of superconductivity. In superconductors, electrons form Cooper pairs due to the attractive forces between them. These pairs are able to move through the material without any resistance, resulting in the phenomenon of superconductivity.
How do superconductors differ from normal conductors?
Superconductors differ from normal conductors in two main ways. Firstly, superconductors have zero resistance, while normal conductors have some level of resistance. Secondly, the critical temperature at which superconductivity occurs is much lower than the melting point of the material, while for normal conductors, the melting point is usually higher than the temperature at which they exhibit their best conducting properties.
